Loading Custom Brushes
I downloaded custom calligraphy brushes online. I'm used to Illustrator where you add them through the brush panel. I'm trying to add them in VS but I'm not seeing anything like that in its brush panel?
Is there any way to add custom brushes to VectorStyler? A review I saw seemed to indicate it had compatibility with Illustrator AI brush files but I can't find any way to import them inside VS.
Is there any way to do this? Perhaps a guide that can be referenced?
@RadiantRoomba There are multiple ways to do this, assuming the brushes are in an AI file.
Select the Panels -> Presets -> Open Brush Preset File command, select the AI file with the brushes and confirm. The brushes will be listed in a new panel, you may need to open the "Brush Types" group in the panel.
Open the AI file as a regular file, and open the Panels -> Styles -> Brush Styles panel. You will find the brushes listed here.
So if I'm looking for any 3rd party vector brushes (like from True Grit Texture Supply etc), are the brushes made for Illustrator the best option in terms of compatibility with VectorStyler?
@JuurGroove said in Loading Custom Brushes:
Yes. But only vector brushes are supported (Photoshop brushes are not supported).
An AI file containing vector brushes can also be opened with the Panels -> Presets -> Open Brush Preset File command to open the file content into a brush preset panel.
