• Direct access to preferred palette for layer color selection
    @Ayo said in Direct access to preferred palette for layer color selection: First Color with color wheel than palettes I will add a state saving to this popup.
  • Few questions about stroke arrows
    @VectorStyler said in Few questions about stroke arrows: Yes, there is a need for a starting size relative to the stroke width. Scan be further adjusted with scale. Yes, the arrow shape is combined with the stroke. That's absolutely fine! just good to know. I could combine the name with the description for the tooltip. No need for that. I see that if you leave description empty it just shows the name. That's fine. Doesn't change the fact that I don't see the purpose or ease of use of 'description'. Available only if the arrow shape is an open path OK. I personally find the 'grayed out' system more helpful if something is not available. Whether it concerns panels or menus. Then you at least know that the function is there but cannot be applied. Then you can experiment until the light comes on. Also no strange empty spaces or jumping rhythms in your layout. I tested this now and the preview sizes did not change here. For me they are also back to the old size after changing display mode and back. Thanks
  • a function request.
    @monsterfox Not directly with shape effects. It can support if mesh gradient is used (it is possible to do a mesh that looks as 1). The mesh gradient nodes are distorted by shape effect. The 4-point distortion shape effect has an image effect version also. Open the Image Effects panel and the [+] button has a Mesh menu with the 4-point effect in it. But these are heavier to render and to work with.
  • Can VS import/place a HEIC file?
    @Boldline HEIC is not supported. I will add this to the features backlog
  • Scaled stroke gets pseudo value
    29
    41k Views
    @VectorStyler said in Scaled stroke gets pseudo value: "convert to actual" Good name! If this becomes a reality in the future, we have ultimately found a solution that meets both needs
  • Gap Tool questions
    @VectorStyler said in Gap Tool questions: This tool is useful in adjusting a rectangular layout on a page (mostly a DTP tool). oh ok - that makes sense in that context
  • Constraign handle to previous segment angle
    @VectorStyler said in Constraign handle to previous segment angle: just drag the line, not from the node but from some location along the line Yes, but then you still have to push the other back
  • Z-position text cursor
    @Ayo yes, I will try to fix this.
  • update 1.2.031 Organizing layers
    @VectorStyler Additionally the extended luxury version Possibly with a grayed-out signaling to indicate if not applicable... [image: 1720612994058-37be3893-0648-4f45-a4a1-99283520bdfd-image.png]
  • Contour Effect Issues
    @Ayo I will try to find a solution for this.
  • Comments and questions about panel 'Color' > Variations
    @VectorStyler I checked Affinity at this point. They call it 'Color Chords'. Nice name by the way. "A color chord is a spread of harmonious colors which can be used in conjunction with each other to produce appealing designs" (from the manual) and that is true. They only preview names. In their case perhaps a better solution than a random fixed color preview if unable to show a correct dynamic color-based preview.
  • What should happen if I tap 'Create Color Scheme'
    @Ayo said in What should happen if I tap 'Create Color Scheme': I feel like Create Color Variation (single) would fit better here than Create Color Scheme. This could be indeed. Do I have to select the color from the Styles window? yes, since it is a style. can be found in the Color window There is also a Color Variations panel.
  • Using Canvas in the workflow
    22
    33k Views
    @Pat said in Using Canvas in the workflow: So it makes more sense to work with presets for everything Only if you want to use it in other documents also, and you do not want to link to the original, that is no automatic update if the original symbol or style definition changes.
    @VectorStyler thank you! that solved it
  • The shape rotates arbitrarily with transform panel
    @VectorStyler The turning knob is determined by the order of tool selections. I've mailed the workspace data to VS-support separately [image: shape-rotate-arbitrarily-2.gif]
  • Blending & Image effect
    @VectorStyler A crash occurred during testing, and finally, the steps to reproduce the crash were identified. 0_1720112738118_Blend Crash.vstyler https://youtu.be/ZaajOxtZMIE
  • Export PDF Artboards, how to get rid of the free canvas?
    @Ayo This is a regression from the last build, one artboard was added into the canvas category, which was not needed. It is fixed and the fix will be in the next build
  • Image import jaggy woes
    @debraspicher said in Image import jaggy woes: Pixel Preview isn't looking quite right either, whether it's 100% or not: I will look into this.
  • How to keep layer contents buildup when duplicating artboard
    @Ayo A fix will be in the next build, it will affect the move tool only (for now). Copy paste has different options (similar to AI).
  • Export Artboard to PNG with a bleed?
    I did have to work around this for printing off an illustration. Printing off the bleed would've been more straightforward, but the nice thing about being able to export a whole Canvas, is even though I have a lot of white space in the end, I was able to crop it down in PS, I could still get a bleed. In this case, I was printing to media that wasn't quite the original document size, so having that extra information in the bleed gave me some extra room to chop around the main art area: [image: 1719593774504-37f43669-0d55-4ccb-b0a1-6ea8ad6c8d44-image.png] Just thought I would share this for informational purposes.
