Zoom to '100% screen size?
Default 100% zoom view is 100% print size view.
Is it possible in Settings to set the 100% zoom to '100% screen size'?Example use: if you take a screenshot and paste it on the artboard at 100% screen size, it retains the same size?
@Ayo Set the Document Setup -> General -> Resolution to some number (72 for example). And then set the View -> Display -> Display Options -> Display section Resolution field to the same number (here uncheck the Default resolution first).
First attempt failed
Document Setup -> Resolution to 218 (my screen resolution Apple Studio Display)
View -> Display Resolution to 218Result: view much to big
After calculating and measuring the ruler screenshots I came to a scaling factor of 33%. 0.33•218 Equals 72!
Second attempt fills the bill
Document Setup -> No need to change, leave resolution to 300* (default)
View -> Display Resolution to 72*leave resolution to 300
Better not change, right? Isn't this the resolution for rasterizing effects for HR printwork RIP (Raster Image Processor)?
