    • Y
      VectorStyler for type design
      • Yaoif
      2070
      @Yaoif It should be, depending on the task of course. VectorStyler aims to have all the features of a high-end vector illustration application. It supports variable and color fonts and has advanced typography features. What are the specific features you are looking for?
      Clicking Quickly Several Times with Zoom View Tool Makes Zooming Unstoppable
      • gotanidea
      2793
      @gotanidea I will try to fix this issue.
    • Maths operation in panels
      • Devil Dinosaur
      10005
      @VectorStyler Works fine now, thanks.
    • Pdf export: All text turns into gibberish
      4989
      @Raaskot said in Pdf export: All text turns into gibberish: Typesetting is incredible cumbersome, unpredictable and very unstable I have to replicate this. The Leading attribute set in the Character panel is applied only to the highlighted characters. There is also a leading property in the Paragraph panel for whole paragraphs.
    • How can I scale type and line space proportionally?
      3196
      Uploaded sample file. Im scaling the box with Alt-Shift-drag The textboxes just acts completely unexpected in this video: Sample video 0_1707132471295_tekstvalg-03.vstyler.zip
    • How do I generate screen dots from blurred shapes?
      5053
      @Raaskot I know you can create something like this and more with the Repeater. As you can see in this thread, for example. https://www.vectorstyler.com/forum/topic/2295/repeater-halftone-problem-on-rasters/53 . . But anyway, here is a little Online Tool that also has something to offer. The result can be saved/downloaded as SVG. https://labs.adobe.com/experiments/hello-halftones/ Here yet a old Thread of mine about that Tool. https://www.vectorstyler.com/forum/topic/1089/tip-halftone-generator-bitmap-to-vector-graphics-svg/4
    • R
      Pen tool behaviour when extending an open path
      • Raven
      2382
      @Raven said in Pen tool behaviour when extending an open path: Is there a preference or modifier key that governs the behaviour? In the context panel, uncheck "Adjustments" Cannot seem to get the node being moved with the spacebar method to snap to the segments or nodes of the same path (if snapping is enabled). Yes, there seems to be an issue here, I opened a bug on this one.
      How do I see brush stroke pressure profile in real-time?
      • A Former User
      9340
      @VectorStyler: I am using VS 1.1. I reckon it is in 1.2 Beta? Don't answer that: I found it! Thanks to @Subpath and @Boldline's screenshots!
    • D
      Meaning of less than 1 pixel
      • DMBrown
      3028
      D
      @VectorStyler Thank you for the explanation. I suspected the precision might be related to internal calculations. I appreciate your time in confirming that is the case.
      Does VS have a scaling brush?
      • Li Xiao
      7109
      @Boldline said in Does VS have a scaling brush?: very excited to see what improvements with repeater that VS will offer! me too
    • Organizing VS for easier understanding and use of styles and presets
      11160
      And… there's no need for icons in the 'Save Style' dialog — a checkbox with a text label that says 'Global' (or anything descriptive) would work great, IMO.
    • Preview
      28
      28
      35352
      @Pat I managed to replicate the preview issue in Windows 11. It seems that the Windows 10 preview solution does not work on Windows 11 file explorer. Not sure yet what causes this issue.
    • O
      Delete Custom Created Presets Style in Image Trace Tool/Panel
      • oleGraf
      4813
      @oleGraf said in Delete Custom Created Presets Style in Image Trace Tool/Panel: Yes I am working with version 1.1.118 for Mac I will add the trace preset listing to 1.1 also.
    • How do I select and move a number of nodes nondistructively with Liquify tool?
      2711
      Cool, thanks!
    • What is the most accurate and easy way to slice this type of shape?
      • Victor Vector
      2901
      @VectorStyler Thank you! I don't know why I wasn't thinking of the combine operations for this. I appreciate the reminder!
      Spacing between Objects
      • Kumr
      8128
      @VectorStyler Thank you for changing to positive values. @VectorStyler said in Spacing between Objects: @Kumr said in Spacing between Objects: I noticed that the values to be in negative to get the spacing, it would help (for my mind) if it is other way around? I will change this.
    • Hide overlapping panels in viewport
      2318
      @Raaskot Tab key for hiding panels should work in 1.2 beta
    • Text cursor almost invisible: Just a one-pixel dot.
      3229
      @Raaskot Yes, I found the error. it is in 1.1 only, 1.2 should be fine. I will provide a fix for this and others soon.
    • When copy paste a layer -- layer name is altered
      7462
      @b77 said in When copy paste a layer -- layer name is altered: need to use 'Copy' from the Edit menu That makes sense. Though still missing the layer structure transfer things work more as expected when using menu-copy. Yet I acknowledge fully your suggestion to @VectorStyler.
    • How can I transform anchor point and see and snap to shapes midpoints?
      2699
      @Subpath Cool, thanks!
