Background objects still disappear when editing nodes above
I know this has been brought up a while back, but I wanted to check in and be sure there was a solution found for it because it affects the way things get edited. the strobe like feel each time something gets moved, the background disappears for the amount of time the object is clicked.
@Boldline There are some refresh issues (already replicated) when editing objects inside transparent layers.
A workaround for this would be to disable the "Direct Preview Editing" in View -> Display.These refresh issues are already fixed for the next build, but please send me this example so that I can check if it is the same kind of problem.
@VectorStyler just sent you the file via email - thanks!
@Boldline Got the file, and the issue can be replicated in the current version.
The next build will fix this.
@VectorStyler terrific! glad for the other upcoming fix and this one as well. thanks!
