    • stroke width line issues remain
      2527
      Inaccurate JPEG Export Result
      • gotanidea
      2488
      @gotanidea Added this to the backlog. Probably the brush strokes are not expanding correctly.
      Link File shortcut broken
      • William Kansepa
      6429
      @VectorStyler said in Link File shortcut broken: @William-Kansepa Uploaded a fix for this, but it is not an update so a manual uninstall / install is needed. @VectorStyler, your responses are truly amazing! Installed and tested, I can confirm that the shortcut is now working as expected. Thank you so much!
    • Cannot paste stored text as file name in save panel in VS
      2873
      @Boldline Added this to the backlog. I think this issue occurred before also.
    • Shift + Nudge Broken?
      9726
      @VectorStyler said in Shift + Nudge Broken?: @Igull I will open a bug on this one. Will try to get it fixed in the next build. Neil
    • Mouse Scroll Issue in Layers Panel
      6917
      @VectorStyler said in Mouse Scroll Issue in Layers Panel: @Igull Got the file, but I cannot replicate the issue here. Scrolling in the Layers panel works fine, using magic mouse. Just tried it with other files and with resetting the workspace, scrolling in the main layers area is reversed from scrolling in the scrollbar area ?? I also tried it with the awful Apple Magic Mouse (I had to retrieve it from the confines of a dark cupboard), does the same thing Neil
      Adding and Removing Color from Palette Takes Seconds
      • gotanidea
      3639
      looks like some performance problem to me even just loading the File took 15 seconds here
    • Stroke Width seems to get stuck at times
      4698
      @encart , @VectorStyler good point I think if someone would set a new width node and the node would look the same as in your picture here. Then it would be a bit easier to use the node handles from the beginning.
      Selecting a line or paragraph of text
      • William Kansepa
      4115
      I can now confirm that this bug has disappeared in update 1.1.087. Thank you so much @VectorStyler.
      Transparency Mask / Gradient Mask Editor erratic behaviour
      • William Kansepa
      3950
      I am happy to report that this is now sorted out and working as expected in update 1.1.087. Thank you so much @VectorStyler.
    • Pen tool has stopped working
      13846
      @VectorStyler ok so deleting the existing settings/workspace files (the ones I emailed you already) fixes the problem with the pen tool here. If anything changes with this, I will let you know
      Transform vs Shape Sizes Not Syncing
      • William Kansepa
      3663
      @VectorStyler said in Transform vs Shape Sizes Not Syncing: @William-Kansepa These sizes have different meaning. The Shape size is before all nondestructive transformation / effects. The size in the Transform panel is the size of the object (after transforms / effects). This can be a bit confusing, but showing the transformed size in the Shape panel might result in other problems. @VectorStyler Thank you. Indeed, I am confused. I guess I will have to relearn the difference between the two panels.
    • Transform Pivot Broken ?
      2696
      @Igull said in Transform Pivot Broken ?: Would it have helped if I had 'adjusted transform pivot' enabled in the prefs do you think Yes, that is the one.
    • N
      Stroke Width Tool Malfunction
      • newcomer
      9826
      @VectorStyler A dot instead of a line is displayed under the cursor. Just like for the middle point. It looks like the handles are treated like the one in the middle.
    • Knife tool doesn't work
      3049
      @VectorStyler Yes, deactivated for both tools.
    • Fonts Previews works occasionally
      3811
      @encart Got it. I will try to replicate this.
    • The character tool has issues doing more than simple rotation
      2798
      @Boldline Added this to the backlog. Probably related to the Direct Shape Transform option.
    • Line Stroke Issue
      2764
      @Igull Looks like an accumulated transform on the stroke. This can be cleared with the Appearance panel -> select Stroke -> and Clear Content Transform in panel menu.
    • font size box partially obscured by default at full screen
      2399
      @Boldline I will try to find a solution for this.
      The Envelope Distortion Tool seems to be buggy
      2869
      @Subpath To add a node just before the starting node, select inside the segment instead of selecting the starting node. I will fix this bug ASAP.
