    Just a Pattern
    47 Posts 7 Posters 61.0k Views 7 Watching
    • Devil DinosaurD Offline
      Devil Dinosaur @Subpath
      @Subpath Cool ! 👍
      Fred.
        Subpath @Devil Dinosaur
        @Devil-Dinosaur, thank you
        Indeed.
        Will do a little Tutorial and show a few Tricks.
          Some optical illusion, i made a while ago.
          The base was simple a yellow stroke where i place a pattern Brush
          in the same size above and the copy scale and rotate it.
          Here the Base
          Here the Pattern
            Another interesting optical illusion.
            Made in VectorStyler and Black Ink
            Dashed Lines, random colorized, the whole thing copied, and
            two copies placed underneath, each with a Gaussian blur image effect
            Black Ink
            Only for Symmetry, because of its symmetry Fusion Feature.
              Played a bit with a multiccolor gradient in strokes.
              You could look at this little tutorial of mine
              https://www.vectorstyler.com/forum/topic/5694/way-to-create-a-multi-color-gradient-from-colors-of-a-color-palette
              • E Offline
                EricP @Subpath
                @Subpath cool effect !
                  Subpath @EricP
                  @EricP
                  Thank you.
                  Yes it looks nice and its realtive easy to do.
                  I just had to relocate some stroke gradients
                  Yes, it looks nice and is relatively easy to create.
                  I just had to reposition some of the gradients a bit.
                  I did this with separate strokes that weren't combined or grouped.
                  If you select all the strokes and then apply a gradient (see the method in the link)
                  over them, the gradients will be in slightly different positions.
                  Ultimately, I actually liked the slightly more chaotic result here even better.
                  Btw i used a concentric gradient
                    marce @Subpath
                    @Subpath Great thread and posts. Thanks. Forum says "you can upvote a user only six times per day", so sorry guys i didnt give the like i wanted meanwhile reading.
                    Memory 48gb ddr4
                    NVMe CT100p 1TB
                      Subpath @marce
                      @marce said in Just a Pattern:
                      @Subpath "Forum says "you can upvote a user only six times per day",
                      Very curious, didn't know that.
                      But dont worry, if my post inspire people or
                      are helpful then this is fine enough 🙂
                        Created using:
                        The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
                        (See Manual how)
                        The Style Picker Feature, which allows you to transfer style attributes
                        from one group of objects to another.
                        You could take look at this Link
                        https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
                          I used a shape with a multi-colored gradient to colorize a bunch of strokes using the Repeater,
                          and transferred the color (style)—using the new Style Picker Tool Feature— to a bunch of
                          other Strokes created with the Blend function.
                          The strokes colored with the Repeater
                          Here the Result
                          1 Reply Last reply Reply Quote 7
                            Took a a gradient from another App with a screenshot and use
                            this raster graphics then to colorize a bunch of strokes with the Repeater.
                            This time no Style Picker Feature where used.
                            I create a a color Palette instead from that bunch of strokes
                            (create Palette from selected Objects)
                            and colored a Swirling Lines Shape after converted it to curves
                            via Colorize with that new palette
                              Made in Vectorstyler, recreate a pattern i found on the Internet
                              mine look a bit different but i am fine with that
                              For anyone who is interested, you need to split the Line
                              in different pieces to create this pattern
                                I more or less replicated a pattern I found online.
                                I couldn't resist using the "Along Stroke" feature
                                in VectorStyler's gradient editor.
