    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
      Played a bit with a multiccolor gradient in strokes.
      You could look at this little tutorial of mine
      https://www.vectorstyler.com/forum/topic/5694/way-to-create-a-multi-color-gradient-from-colors-of-a-color-palette
      • E Offline
        EricP @Subpath
        @Subpath cool effect !
          Subpath @EricP
          @EricP
          Thank you.
          Yes it looks nice and its realtive easy to do.
          I just had to relocate some stroke gradients
          Yes, it looks nice and is relatively easy to create.
          I just had to reposition some of the gradients a bit.
          I did this with separate strokes that weren't combined or grouped.
          If you select all the strokes and then apply a gradient (see the method in the link)
          over them, the gradients will be in slightly different positions.
          Ultimately, I actually liked the slightly more chaotic result here even better.
          Btw i used a concentric gradient
            marce @Subpath
            @Subpath Great thread and posts. Thanks. Forum says "you can upvote a user only six times per day", so sorry guys i didnt give the like i wanted meanwhile reading.
            Memory 48gb ddr4
            NVMe CT100p 1TB
              Subpath @marce
              @marce said in Just a Pattern:
              @Subpath "Forum says "you can upvote a user only six times per day",
              Very curious, didn't know that.
              But dont worry, if my post inspire people or
              are helpful then this is fine enough 🙂
                Created using:
                The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
                (See Manual how)
                The Style Picker Feature, which allows you to transfer style attributes
                from one group of objects to another.
                You could take look at this Link
                https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
                  I used a shape with a multi-colored gradient to colorize a bunch of strokes using the Repeater,
                  and transferred the color (style)—using the new Style Picker Tool Feature— to a bunch of
                  other Strokes created with the Blend function.
                  The strokes colored with the Repeater
                  Here the Result
                  1 Reply Last reply Reply Quote 8
                    Took a a gradient from another App with a screenshot and use
                    this raster graphics then to colorize a bunch of strokes with the Repeater.
                    This time no Style Picker Feature where used.
                    I create a a color Palette instead from that bunch of strokes
                    (create Palette from selected Objects)
                    and colored a Swirling Lines Shape after converted it to curves
                    via Colorize with that new palette
                      Made in Vectorstyler, recreate a pattern i found on the Internet
                      mine look a bit different but i am fine with that
                      For anyone who is interested, you need to split the Line
                      in different pieces to create this pattern
                        I more or less replicated a pattern I found online.
                        I couldn't resist using the "Along Stroke" feature
                        in VectorStyler's gradient editor.
                          This was inspired by "string art"; I wanted to experiment with creating it
                          as vector graphics and applying gradients to the individual paths to see
                          what kind of patterns would emerge.
                          The String Art was made in Nodebox because its very easy to
                          create Point/Node Pattern with it.
                          https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
                          The coloring was created in VectorStyler; which allows to create gradients along a path
                          and allows them to be applied to the design's paths using the "Style Picker" group function.
                            Another Variation of it
                            M 1 Reply Last reply Reply Quote 2
                              monsterfox @Subpath
                              @Subpath These graphics look quite unique. I’m curious: can VectorStyler create them at the moment?
                                Subpath @monsterfox
                                @monsterfox
                                I think some of the Designs would be possible in Vectorstyler
                                all you need is a straight Line, rotate it a bit and copy and repeate it
                                But i think it is way easier to do it in Nodebox because one would have more Options
                                when you could set single Points and connect those Points with a Line i dont think
                                that Vectorstyler could set single points.
                                To set single points and connect them its very easy in Nodebox. (Nodebox is free, PC and Mac
                                in the mean time there is also a Version for Silicon based Macs )
                                All you need is a Path and a Point Node which say how much Points a Path should have.
                                This way you could create all kind of Point Patterns and connect them.
                                Here how the base Structure is made
                                and here the whole Design
                                  Some additional notes regarding Points in NodeBox:
                                  Points serve not only to connect lines or paths.
                                  They can also be used to specify positions for shapes or designs.
                                  And since this all is Node-based in Nodebox, it is very easy to replace
                                  one shape with another or to modify the design.
                                  Not to forget that Nodebox is a pretty good compainion to Vectorstyler
                                  NB has .SVG and PDF Export and you could import .SVGs
                                    monsterfox @Subpath
                                    @Subpath This is a node-based program, which I’m afraid won’t work for me. Just like creating materials in C4D, it requires connecting nodes. This kind of workflow isn’t my strong suit.
                                      Subpath @monsterfox
                                      @monsterfox
                                      No problem if it doesn't work for you or isn't a good fit.
                                      I only use it for specific tasks myself. Creating vector graphics using nodes certainly
                                      has its merits and its fun to use. I didn't find the basic principles hard to learn—and
                                      I’m really not the brightest bulb.
                                        The design was created using Nodebox (which is free).
                                        I tried to copy and scale it within VectorStyler, but I couldn't find
                                        a way that produced a good result.
                                        However, the coloring was done in VectorStyler—and this is where
                                        the "Style Picker Group" feature really shines. The design consists of 80 objects;
                                        I created a single stroke, applied a gradient along a path, and then duplicated
                                        it until I had 80 copies.
                                        Finally, I grouped the design elements and the strokes, and then applied the styles
                                        to the whole set using the Style Picker.
                                        • L Online
                                          Li Xiao @Subpath
                                          @Subpath said in Just a Pattern:
                                          VectorStyler can actually create this. I'll take some time to record a video
                                            Subpath @Li Xiao
                                            @Li-Xiao
                                            No problem, just take your time.
                                            I’m very interested to see how you solve this—
                                            and I imagine other users are, too.
                                            In my own attempts, VectorStyler always distorts the shapes being duplicated;
                                            maintaining consistent spacing between them also proves to be an issue.
                                            Here how the Result looks in Nodebox
