    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
    • E Offline
      EricP @Subpath
      @Subpath cool effect !
        Subpath @EricP
        @EricP
        Thank you.
        Yes it looks nice and its realtive easy to do.
        I just had to relocate some stroke gradients
        Yes, it looks nice and is relatively easy to create.
        I just had to reposition some of the gradients a bit.
        I did this with separate strokes that weren't combined or grouped.
        If you select all the strokes and then apply a gradient (see the method in the link)
        over them, the gradients will be in slightly different positions.
        Ultimately, I actually liked the slightly more chaotic result here even better.
        Btw i used a concentric gradient
          marce @Subpath
          @Subpath Great thread and posts. Thanks. Forum says "you can upvote a user only six times per day", so sorry guys i didnt give the like i wanted meanwhile reading.
          Memory 48gb ddr4
          NVMe CT100p 1TB
            Subpath @marce
            @marce said in Just a Pattern:
            @Subpath "Forum says "you can upvote a user only six times per day",
            Very curious, didn't know that.
            But dont worry, if my post inspire people or
            are helpful then this is fine enough 🙂
              Created using:
              The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
              (See Manual how)
              The Style Picker Feature, which allows you to transfer style attributes
              from one group of objects to another.
              You could take look at this Link
              https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
                I used a shape with a multi-colored gradient to colorize a bunch of strokes using the Repeater,
                and transferred the color (style)—using the new Style Picker Tool Feature— to a bunch of
                other Strokes created with the Blend function.
                The strokes colored with the Repeater
                Here the Result
                1 Reply Last reply Reply Quote 8
                  Took a a gradient from another App with a screenshot and use
                  this raster graphics then to colorize a bunch of strokes with the Repeater.
                  This time no Style Picker Feature where used.
                  I create a a color Palette instead from that bunch of strokes
                  (create Palette from selected Objects)
                  and colored a Swirling Lines Shape after converted it to curves
                  via Colorize with that new palette
                    Made in Vectorstyler, recreate a pattern i found on the Internet
                    mine look a bit different but i am fine with that
                    For anyone who is interested, you need to split the Line
                    in different pieces to create this pattern
                      I more or less replicated a pattern I found online.
                      I couldn't resist using the "Along Stroke" feature
                      in VectorStyler's gradient editor.
                        This was inspired by "string art"; I wanted to experiment with creating it
                        as vector graphics and applying gradients to the individual paths to see
                        what kind of patterns would emerge.
                        The String Art was made in Nodebox because its very easy to
                        create Point/Node Pattern with it.
                        https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
                        The coloring was created in VectorStyler; which allows to create gradients along a path
                        and allows them to be applied to the design's paths using the "Style Picker" group function.
                          Another Variation of it
                          M 1 Reply Last reply Reply Quote 2
                            monsterfox @Subpath
                            @Subpath These graphics look quite unique. I’m curious: can VectorStyler create them at the moment?
                              Subpath @monsterfox
                              @monsterfox
                              I think some of the Designs would be possible in Vectorstyler
                              all you need is a straight Line, rotate it a bit and copy and repeate it
                              But i think it is way easier to do it in Nodebox because one would have more Options
                              when you could set single Points and connect those Points with a Line i dont think
                              that Vectorstyler could set single points.
                              To set single points and connect them its very easy in Nodebox. (Nodebox is free, PC and Mac
                              in the mean time there is also a Version for Silicon based Macs )
                              All you need is a Path and a Point Node which say how much Points a Path should have.
                              This way you could create all kind of Point Patterns and connect them.
                              Here how the base Structure is made
                              and here the whole Design
                                Some additional notes regarding Points in NodeBox:
                                Points serve not only to connect lines or paths.
                                They can also be used to specify positions for shapes or designs.
                                And since this all is Node-based in Nodebox, it is very easy to replace
                                one shape with another or to modify the design.
                                Not to forget that Nodebox is a pretty good compainion to Vectorstyler
                                NB has .SVG and PDF Export and you could import .SVGs
                                  monsterfox @Subpath
                                  @Subpath This is a node-based program, which I’m afraid won’t work for me. Just like creating materials in C4D, it requires connecting nodes. This kind of workflow isn’t my strong suit.
                                    Subpath @monsterfox
                                    @monsterfox
                                    No problem if it doesn't work for you or isn't a good fit.
                                    I only use it for specific tasks myself. Creating vector graphics using nodes certainly
                                    has its merits and its fun to use. I didn't find the basic principles hard to learn—and
                                    I’m really not the brightest bulb.
                                      The design was created using Nodebox (which is free).
                                      I tried to copy and scale it within VectorStyler, but I couldn't find
                                      a way that produced a good result.
                                      However, the coloring was done in VectorStyler—and this is where
                                      the "Style Picker Group" feature really shines. The design consists of 80 objects;
                                      I created a single stroke, applied a gradient along a path, and then duplicated
                                      it until I had 80 copies.
                                      Finally, I grouped the design elements and the strokes, and then applied the styles
                                      to the whole set using the Style Picker.
                                      • L Offline
                                        Li Xiao @Subpath
                                        @Subpath said in Just a Pattern:
                                        VectorStyler can actually create this. I'll take some time to record a video
                                          Subpath @Li Xiao
                                          @Li-Xiao
                                          No problem, just take your time.
                                          I’m very interested to see how you solve this—
                                          and I imagine other users are, too.
                                          In my own attempts, VectorStyler always distorts the shapes being duplicated;
                                          maintaining consistent spacing between them also proves to be an issue.
                                          Here how the Result looks in Nodebox
                                          • L Offline
                                            Li Xiao @Subpath
                                            This is quite easy, just use the Blend Tool
                                            This is the specific example I was referring to for the video I plan to record.
