    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
    • H Offline
      Harry @Subpath
      @Subpath said in Just a Pattern:
      Made two paths and a blend between them
      the deformation was made in CorelDraw because
      they look better, but VectorStyler wants to improve
      the deformation tools
      The rest are made in VectorStyler.
      These are three times the same paths/shapes (layered)
      one for the fill, one for the mosaic and one for the transparent
      and randomly colored mosaic to give it a little more life
      Interesting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap πŸ™‚ - example
        Subpath @Harry
        @Harry
        Thanks, you're actually on the right track πŸ™‚
        The pattern you mentioned is one of several experiments that
        should ultimately led to something like a cobblestone/mosaic.
        My goal was to figure out a way how to create something like
        that in Vectorstyler. I'm still experimenting a bit, but when
        everything will fall together, I'll post a tutorial.
          @Li-Xiao created a few designs in this thread
          https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effect
          I couldn't resist taking one and trying out Colorize.
          Here the needed Steps
          Select the Design
          Expand Appearence
          Ungroup the Design
          Do a Boolean Divide
          Fill the Result, color doesnt matter
          (colorize work on filled objects only)
          Call Colorize
          Call Colorize Options
          deselect "Change Strokes"
          Choose a Palette/or some Colors
          ( you can create your own Palette
          or select some colors using the
          system palette )
          You could also color only the Strokes if you like.
          Here another one
          • L Online
            Li Xiao @Subpath
            @Subpath Very beautiful πŸ‘ , I also really enjoy using Colorize.
              Metaball try made in VectorStyler
              Devil DinosaurD 1 Reply Last reply Reply Quote 5
              • Devil DinosaurD Offline
                Devil Dinosaur @Subpath
                @Subpath Cool ! πŸ‘
                Fred.
                  Subpath @Devil Dinosaur
                  @Devil-Dinosaur, thank you
                  Indeed.
                  Will do a little Tutorial and show a few Tricks.
                    Some optical illusion, i made a while ago.
                    The base was simple a yellow stroke where i place a pattern Brush
                    in the same size above and the copy scale and rotate it.
                    Here the Base
                    Here the Pattern
                      Another interesting optical illusion.
                      Made in VectorStyler and Black Ink
                      Dashed Lines, random colorized, the whole thing copied, and
                      two copies placed underneath, each with a Gaussian blur image effect
                      Black Ink
                      Only for Symmetry, because of its symmetry Fusion Feature.
                        Played a bit with a multiccolor gradient in strokes.
                        You could look at this little tutorial of mine
                        https://www.vectorstyler.com/forum/topic/5694/way-to-create-a-multi-color-gradient-from-colors-of-a-color-palette
                        • E Offline
                          EricP @Subpath
                          @Subpath cool effect !
                            Subpath @EricP
                            @EricP
                            Thank you.
                            Yes it looks nice and its realtive easy to do.
                            I just had to relocate some stroke gradients
                            Yes, it looks nice and is relatively easy to create.
                            I just had to reposition some of the gradients a bit.
                            I did this with separate strokes that weren't combined or grouped.
                            If you select all the strokes and then apply a gradient (see the method in the link)
                            over them, the gradients will be in slightly different positions.
                            Ultimately, I actually liked the slightly more chaotic result here even better.
                            Btw i used a concentric gradient
                              marce @Subpath
                              @Subpath Great thread and posts. Thanks. Forum says "you can upvote a user only six times per day", so sorry guys i didnt give the like i wanted meanwhile reading.
                              Memory 48gb ddr4
                              NVMe CT100p 1TB
                                Subpath @marce
                                @marce said in Just a Pattern:
                                @Subpath "Forum says "you can upvote a user only six times per day",
                                Very curious, didn't know that.
                                But dont worry, if my post inspire people or
                                are helpful then this is fine enough πŸ™‚
                                  Created using:
                                  The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
                                  (See Manual how)
                                  The Style Picker Feature, which allows you to transfer style attributes
                                  from one group of objects to another.
                                  You could take look at this Link
                                  https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
                                    I used a shape with a multi-colored gradient to colorize a bunch of strokes using the Repeater,
                                    and transferred the color (style)β€”using the new Style Picker Tool Featureβ€” to a bunch of
                                    other Strokes created with the Blend function.
                                    The strokes colored with the Repeater
                                    Here the Result
                                    1 Reply Last reply Reply Quote 8
                                      Took a a gradient from another App with a screenshot and use
                                      this raster graphics then to colorize a bunch of strokes with the Repeater.
                                      This time no Style Picker Feature where used.
                                      I create a a color Palette instead from that bunch of strokes
                                      (create Palette from selected Objects)
                                      and colored a Swirling Lines Shape after converted it to curves
                                      via Colorize with that new palette
                                        Made in Vectorstyler, recreate a pattern i found on the Internet
                                        mine look a bit different but i am fine with that
                                        For anyone who is interested, you need to split the Line
                                        in different pieces to create this pattern
                                          I more or less replicated a pattern I found online.
                                          I couldn't resist using the "Along Stroke" feature
                                          in VectorStyler's gradient editor.
                                            This was inspired by "string art"; I wanted to experiment with creating it
                                            as vector graphics and applying gradients to the individual paths to see
                                            what kind of patterns would emerge.
                                            The String Art was made in Nodebox because its very easy to
                                            create Point/Node Pattern with it.
                                            https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
                                            The coloring was created in VectorStyler; which allows to create gradients along a path
                                            and allows them to be applied to the design's paths using the "Style Picker" group function.
