    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
      @Li-Xiao created a few designs in this thread
      https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effect
      I couldn't resist taking one and trying out Colorize.
      Here the needed Steps
      Select the Design
      Expand Appearence
      Ungroup the Design
      Do a Boolean Divide
      Fill the Result, color doesnt matter
      (colorize work on filled objects only)
      Call Colorize
      Call Colorize Options
      deselect "Change Strokes"
      Choose a Palette/or some Colors
      ( you can create your own Palette
      or select some colors using the
      system palette )
      You could also color only the Strokes if you like.
      Here another one
      • L Online
        Li Xiao @Subpath
        @Subpath Very beautiful ๐Ÿ‘ , I also really enjoy using Colorize.
          Metaball try made in VectorStyler
          Devil DinosaurD 1 Reply Last reply Reply Quote 5
          • Devil DinosaurD Offline
            Devil Dinosaur @Subpath
            @Subpath Cool ! ๐Ÿ‘
            Fred.
              Subpath @Devil Dinosaur
              @Devil-Dinosaur, thank you
              Indeed.
              Will do a little Tutorial and show a few Tricks.
                Some optical illusion, i made a while ago.
                The base was simple a yellow stroke where i place a pattern Brush
                in the same size above and the copy scale and rotate it.
                Here the Base
                Here the Pattern
                  Another interesting optical illusion.
                  Made in VectorStyler and Black Ink
                  Dashed Lines, random colorized, the whole thing copied, and
                  two copies placed underneath, each with a Gaussian blur image effect
                  Black Ink
                  Only for Symmetry, because of its symmetry Fusion Feature.
                    Played a bit with a multiccolor gradient in strokes.
                    You could look at this little tutorial of mine
                    https://www.vectorstyler.com/forum/topic/5694/way-to-create-a-multi-color-gradient-from-colors-of-a-color-palette
                    • E Offline
                      EricP @Subpath
                      @Subpath cool effect !
                        Subpath @EricP
                        @EricP
                        Thank you.
                        Yes it looks nice and its realtive easy to do.
                        I just had to relocate some stroke gradients
                        Yes, it looks nice and is relatively easy to create.
                        I just had to reposition some of the gradients a bit.
                        I did this with separate strokes that weren't combined or grouped.
                        If you select all the strokes and then apply a gradient (see the method in the link)
                        over them, the gradients will be in slightly different positions.
                        Ultimately, I actually liked the slightly more chaotic result here even better.
                        Btw i used a concentric gradient
                          marce @Subpath
                          @Subpath Great thread and posts. Thanks. Forum says "you can upvote a user only six times per day", so sorry guys i didnt give the like i wanted meanwhile reading.
                          Memory 48gb ddr4
                          NVMe CT100p 1TB
                            Subpath @marce
                            @marce said in Just a Pattern:
                            @Subpath "Forum says "you can upvote a user only six times per day",
                            Very curious, didn't know that.
                            But dont worry, if my post inspire people or
                            are helpful then this is fine enough ๐Ÿ™‚
                              Created using:
                              The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
                              (See Manual how)
                              The Style Picker Feature, which allows you to transfer style attributes
                              from one group of objects to another.
                              You could take look at this Link
                              https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
                                I used a shape with a multi-colored gradient to colorize a bunch of strokes using the Repeater,
                                and transferred the color (style)โ€”using the new Style Picker Tool Featureโ€” to a bunch of
                                other Strokes created with the Blend function.
                                The strokes colored with the Repeater
                                Here the Result
                                1 Reply Last reply Reply Quote 8
                                  Took a a gradient from another App with a screenshot and use
                                  this raster graphics then to colorize a bunch of strokes with the Repeater.
                                  This time no Style Picker Feature where used.
                                  I create a a color Palette instead from that bunch of strokes
                                  (create Palette from selected Objects)
                                  and colored a Swirling Lines Shape after converted it to curves
                                  via Colorize with that new palette
                                    Made in Vectorstyler, recreate a pattern i found on the Internet
                                    mine look a bit different but i am fine with that
                                    For anyone who is interested, you need to split the Line
                                    in different pieces to create this pattern
                                      I more or less replicated a pattern I found online.
                                      I couldn't resist using the "Along Stroke" feature
                                      in VectorStyler's gradient editor.
                                        This was inspired by "string art"; I wanted to experiment with creating it
                                        as vector graphics and applying gradients to the individual paths to see
                                        what kind of patterns would emerge.
                                        The String Art was made in Nodebox because its very easy to
                                        create Point/Node Pattern with it.
                                        https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
                                        The coloring was created in VectorStyler; which allows to create gradients along a path
                                        and allows them to be applied to the design's paths using the "Style Picker" group function.
                                          Another Variation of it
                                          M 1 Reply Last reply Reply Quote 2
                                            monsterfox @Subpath
                                            @Subpath These graphics look quite unique. Iโ€™m curious: can VectorStyler create them at the moment?
