Paragraph style - can't be changed through the panel
@Pat said in Paragraph style - can't be changed through the panel:
the best and simplest way is to mimic exactly what is done in InDesign or Publisher (styles work well here too) in creating, applying and updating a style
It should be similar, unless there is some bug. I will review the whole thing before the next release.
@VectorStyler said in Paragraph style - can't be changed through the panel:
@VectorStyler thank you
(no need for plenty of options (to start with))
@VectorStyler no, we're not there yet.
- I define a paragraph style (e.g., title)
- I apply it to different paragraphs
- I change the font and update the style
- it's OK for the part of the text I've changed, but not for the others: the informations in the panel are not fully correct
So it is basically showing incorrect attributes in the character panel.
I will try to replicate this. Send me the file from that screenshot.
@VectorStyler Sorry, didn't save this one... I start to have too many test files
but I guess you could reproduce this issue easily.
@VectorStyler It seems to me that it's still not very user-friendly and buggy.
To improve workflow: would it be possible to apply styles with a simple (mouse/pen) click?
Updating a style after modifying the text still doesn't work.
Yes, in the panel menu -> Listing Mode, select "Edit on Double Click". Then single click will apply.
I tried to replicate this, but the paragraph style was updated here.
If you can send a file for this one, it might help replicating it. Thanks!
That's something. I'm convinced that this option isn't very useful. I don't remember how it is in InDesign but I think that styles are applied by a simple click.
If you can send a file for this one, it might help replicating it. Thanks!I've recorded the issue and will sent you the mp4.
@Pat Got the recording, thanks!
@VectorStyler I hope this helps and that what I want to show is made clear
Replicated. I found two issues:
- the paragraph changes after updating (should not). This can be fixed with a Control+R refresh
- the [+] marker on the name should go away after applying the paragraph style.
I will try to fix this problems for the next build.
@VectorStyler Yes, that's right. Thanks
I'll resume testing with the next build.
@VectorStyler ...is still not working
- changing the font style of a paragraph
- define a new paragraph style (e.g., title)
- the new style appears in the list
But: - it can be applied to another paragraph without taking all the defined criteria into account
- it can be applied to another paragraph but reverting to the default style is not correct, as the text may retain the font size of the new style
I think it would be a good idea to test these text styles in depth. As long as it doesn't work, it will be impossible to use VS for in-depth text control in a layout.
@Pat Added this to the backlog. Will try to replicate this and test it more.
I could not replicate these two, or I did not understood them:
@VectorStyler I've just tried again and had different issues. I've recorded it and I'm sending you the video.
@Pat Got it. Thanks!
This can be replicated.
@VectorStyler testing the paragraph styles:
so far so good except thatthe chosen font is still not displayed in the character panel:Edit: no, synchronisation is not always working as it should. Sorry, I stop testing this up to the next updates.
@Pat There is still work to do here.
Does this refer to the character panel update, or to the paragraph style creation from the "Paragraph Style" panel?
