    Paragraph style - can't be changed through the panel
    49 Posts 2 Posters 113.0k Views 2 Watching
    • B Offline
      B-Vs-V @VectorStyler
      @VectorStyler I've sent you two files.
      I will thoroughly test the styles again with the next build ☺
      • B Offline
        @VectorStyler no, the paragraph styles don't work, or at least I don't know how to use them in the same way as in a page layout program. I'm going to stop testing page layout and styles.
          VectorStyler @B-Vs-V
          @Pat I will reopen this issue and will try to replicate it again.
          I have the files you sent me previously.
          Maybe sending the settings / workspace file might also help in replicating. Thanks!
          • B Offline
            @VectorStyler In a DP app, there's nothing more straightforward (and important) than defining paragraph styles, and if we want to make the most of VS for page layouts, it should work just the same. The settings/WSP files are new ones (I did reset VS a week or so ago).
              @Pat said in Paragraph style - can't be changed through the panel:
              I agree. I will try to find the bug here and have a fix for the next build.
              • B Offline
                @VectorStyler said in Paragraph style - can't be changed through the panel:
                @VectorStyler for styles, the best and simplest way is to mimic exactly what is done in InDesign or Publisher (styles work well here too) in creating, applying and updating a style ☺
                  It should be similar, unless there is some bug. I will review the whole thing before the next release.
                  • B Offline
                    @VectorStyler thank you ☺ (no need for plenty of options (to start with))
                    • B Offline
                      B-Vs-V
                      @VectorStyler no, we're not there yet.
                      1. I define a paragraph style (e.g., title)
                      2. I apply it to different paragraphs
                      3. I change the font and update the style
                      4. it's OK for the part of the text I've changed, but not for the others: the informations in the panel are not fully correct
                        So it is basically showing incorrect attributes in the character panel.
                        I will try to replicate this. Send me the file from that screenshot.
                        • B Offline
                          @VectorStyler Sorry, didn't save this one... I start to have too many test files ☺ but I guess you could reproduce this issue easily.
                          • B Offline
                            @VectorStyler It seems to me that it's still not very user-friendly and buggy.
                            To improve workflow: would it be possible to apply styles with a simple (mouse/pen) click?
                            Updating a style after modifying the text still doesn't work.
                              Yes, in the panel menu -> Listing Mode, select "Edit on Double Click". Then single click will apply.
                              I tried to replicate this, but the paragraph style was updated here.
                              If you can send a file for this one, it might help replicating it. Thanks!
                              • B Offline
                                That's something. I'm convinced that this option isn't very useful. I don't remember how it is in InDesign but I think that styles are applied by a simple click.
                                I've recorded the issue and will sent you the mp4.
                                  @Pat Got the recording, thanks!
                                  • B Offline
                                    @VectorStyler I hope this helps and that what I want to show is made clear ☺
                                      Replicated. I found two issues:
                                      • the paragraph changes after updating (should not). This can be fixed with a Control+R refresh
                                      • the [+] marker on the name should go away after applying the paragraph style.
                                      I will try to fix this problems for the next build.
                                      • B Offline
                                        @VectorStyler Yes, that's right. Thanks ☺ I'll resume testing with the next build.
                                        • B Offline
                                          @VectorStyler ...is still not working ☹ :
                                          • changing the font style of a paragraph
                                          • define a new paragraph style (e.g., title)
                                          • the new style appears in the list
                                            But:
                                          • it can be applied to another paragraph without taking all the defined criteria into account
                                          • it can be applied to another paragraph but reverting to the default style is not correct, as the text may retain the font size of the new style
                                          I think it would be a good idea to test these text styles in depth. As long as it doesn't work, it will be impossible to use VS for in-depth text control in a layout.
                                            @Pat Added this to the backlog. Will try to replicate this and test it more.
