Paragraph style - can't be changed through the panel
@VectorStyler Sorry, didn't save this one... I start to have too many test files
but I guess you could reproduce this issue easily.
@VectorStyler It seems to me that it's still not very user-friendly and buggy.
To improve workflow: would it be possible to apply styles with a simple (mouse/pen) click?
Updating a style after modifying the text still doesn't work.
@Pat said in Paragraph style - can't be changed through the panel:
Yes, in the panel menu -> Listing Mode, select "Edit on Double Click". Then single click will apply.
I tried to replicate this, but the paragraph style was updated here.
If you can send a file for this one, it might help replicating it. Thanks!
@VectorStyler said in Paragraph style - can't be changed through the panel:
That's something. I'm convinced that this option isn't very useful. I don't remember how it is in InDesign but I think that styles are applied by a simple click.
If you can send a file for this one, it might help replicating it. Thanks!I've recorded the issue and will sent you the mp4.
@Pat Got the recording, thanks!
@VectorStyler I hope this helps and that what I want to show is made clear
Replicated. I found two issues:
- the paragraph changes after updating (should not). This can be fixed with a Control+R refresh
- the [+] marker on the name should go away after applying the paragraph style.
I will try to fix this problems for the next build.
@VectorStyler Yes, that's right. Thanks
I'll resume testing with the next build.
@VectorStyler ...is still not working
- changing the font style of a paragraph
- define a new paragraph style (e.g., title)
- the new style appears in the list
But: - it can be applied to another paragraph without taking all the defined criteria into account
- it can be applied to another paragraph but reverting to the default style is not correct, as the text may retain the font size of the new style
I think it would be a good idea to test these text styles in depth. As long as it doesn't work, it will be impossible to use VS for in-depth text control in a layout.
@Pat Added this to the backlog. Will try to replicate this and test it more.
I could not replicate these two, or I did not understood them:
@VectorStyler I've just tried again and had different issues. I've recorded it and I'm sending you the video.
@Pat Got it. Thanks!
This can be replicated.
@VectorStyler testing the paragraph styles:
so far so good except thatthe chosen font is still not displayed in the character panel:Edit: no, synchronisation is not always working as it should. Sorry, I stop testing this up to the next updates.
@Pat There is still work to do here.
Does this refer to the character panel update, or to the paragraph style creation from the "Paragraph Style" panel?
@VectorStyler Paragraphe style panel.
I made a recording of the paragraph style syncing: https://recordit.co/0kiu9aB4s9
Maybe I do something different here, attached the file also: 0_1701886168646_paragraphstyle2.vstyler
In this file I have the default paragraph style and a new (not yet edited) "title1" style. In the text I changed some character and paragraph attributes, but still links to the default style at first.
The syncing is done with he highlighted button (below).
One problem: if the panel is set to apply the style in a single click, then syncing will not work, since by selecting the style (to sync) will apply the style, so there is nothing to sync.
@VectorStyler I tried to repeat this problem but VS crashed (crash report sent).
First, I was able to define a paragraph style and apply it to different parts of the text. It was easy to switch between the two styles.
If I select a piece of text in a paragraph (with a paragraph style, e.g. title) and change the characteristics of the text (font, size, etc.), the synchronisation doesn't always work and I always ended up with "unstyled" text, and Ctrl+R does nothing.
I didn't record this time, but it's like at the end of the video I sent you earlier.
Got the crash report. Was the Guidelines panel open? Seems to be caused by that.
Please send me the workspace and settings files (Help -> Reveal Workspace Folder).
