    2. Features and Ideas
    3. Implemented Features
      Search feature in palettes
      • Arde
      26
      26
      46609
      @Boldline The grey box indicates a color group header. Colors from ASE are organized in groups. I will look into the registration color import issue.
    • V
      Change Ruler Units by Right clicking on Ruler
      • Vector-Rock
      5843
      @vectoradmin Very nice. Great to see it made it into Build 1.0.025 RC2 (correction) Thank You!
      Option to reverse mouse wheel scroll direction to zoom and several wishes.
      • baoyu
      6443
      @vectoradmin Great! Thank you developer!
    • Node options using the cursor
      17072
      @vectoradmin Yes! loving it so far! I'll keep testing it and using it and let you know if anything else comes up. This is a big help thank you!
      Add file type groups in the list of supported files when importing
      • Arde
      3865
      @Arde This should work in the new build (1.0.022).
      Default location for Windows color profiles...
      • Arde
      6012
      @Arde The suggested default location is added in the new build (1.0.022).
      Improved pair kerning
      • Arde
      6011
      @vectoradmin Adjusting tracking at the cursor position should work in the new build (1.0.022). Use keys Control+Option+Comma to decrease and Control+Option+Period to increase tracking.
      A small but important usability improvement: sub menu delay
      • Arde
      7160
      @vectoradmin said in A small but important usability improvement: sub menu delay: The new build improves on the Windows menu handling. Thanks, that makes all the difference.
      Recognizing spot colors on PDF import
      • Arde
      10016
      @Arde Including Pantone requires a license. But it can be imported if available from a number of palette formats. I add to the backlog the color search / match feature.
      Individual corners and text layer names
      • Arde
      6773
      @vectoradmin said in Individual corners and text layer names: The new build shows a couple of words from unnamed text objects in the layers panel. Thanks, great!
    • About the [grid shape_] tool. ver.1.0.019
      5067
      @vectoradmin Thanks for a job well done. I've confirmed. I also expect to create by specifying columns and rows. Near future.
      Consider simplifying interface
      • grix
      33
      33
      63637
      @vectoradmin thank you, managing them is much easier now.
    • Lasso tool?
      5660
      @syllie thank you!!!!! I figured it was in there somewhere. I was just missing it somehow. You're awesome
    • Less jarring snapping of panels
      5917
      @vectoradmin - the panels are much improved in the new beta! I like how it now highlights where it can go and it's not jarring anymore. good work
    • Stroke panel - Dash / Stripe / Profile dialog a bit underwhelming
      • syllie
      8222
      @vectoradmin I like how this one has been changed in build 1.0.018 RC1 - much clearer! Thank you.
    • Use shape editor to allow individual edit to shape while grouped?
      6130
      @vectoradmin Thanks for explaining that and your patience with me.
    • The maximum set value of the character deformation
      5788
      @vectoradmin I confirmed the operation. Thank you This is an important function in Japanese and mathematical formulas.
    • Dragging handle into node be made to snap magnetic
      8895
      @Boldline The original location of points (or objects) is a snapping location. This can be disabled with the Snap to Original option from the snapping panel menu. Snapping settings are document specific. New documents will inherit the most recent snapping setting. But existing documents (opened from a file) will load their last snapping settings. Should this be an option?
    • Cursor Icon Change
      5922
      The new build improves cursor handling in the transform tool (including rotating the cursors).
    • Halftone threshold
      5747
      @vectoradmin Awesome! I just tried it out - it makes a HUGE difference. Nice to be able to make a quick live image effect, get it set in the pop up box and see the results. Question - is there a reason opacity is not a preview option? I know this was something we talked about in other areas of the program a few months ago.
