  • use a point to lead the whole
    @monsterfox There is no such feature now. Not clear how this would work. What happens if the blue nodes on the left (36) are moved or the line is changed to a curve?
    @William-Kansepa Thanks for explaining your thoughts on this. I agree with you completely. There are several examples like this in VS where the main task itself is a little more complex than it needs to be. VS has so many extra cool features that I don't want to compromise those either. I was asking you for more elaboration because we can all watch the video and pick up different things we like/dislike about the process being demonstrated. There's a value in articulating our own view and adding that to the conversation for improvement. I appreciate what you shared.
  • Curvature tool as a modifier key option to the existing pen tool
    @VectorStyler Thank you! this will be an awesome improvement. At the risk of beating a dead horse, I would prefer it to NOT be a new tool in and of itself because I think it would be something a user would need occasionally, but not enough to go switch to a dedicated tool to do so. Hence why I was thinking a modifier key option while using the pen tool would suffice. Just my opinion. You would know best what fits the VS scheme!
    @Boldline Currently the font is not included in the attribute copying. I added this to the feature backlog.
  • Expand the color choosing options for the Bucket Fill Tool
    @Boldline said in Expand the color choosing options for the Bucket Fill Tool: So unless I am missing a step, I am unable to preemptively choose the color I want the selected shape to be filled with. I think that changing the color will work after the first bucket fill click. The problem is indeed that selecting the objects will update the current color. I will try to improve this.
  • Regarding the selection-related features
    @VectorStyler Thanks. There are two areas for improvement: allowing multiple selections in the preset list overlay and enabling the selected nodes to save presets. https://go.screenpal.com/watch/cZhllAVLiIa
  • Artboard printing / exporting in the order set by the user.
    @Harry Not for the export tool, only for printing. I will try to add it for export also.
  • Webpage Font Hard to Read
    @Teddy Keep critiquing because it will help the development of the UI/UX aspect of the program. Some aspects of application design is subjective to the general user, but with more input across the board, hopefully it becomes a lot clearer to the developer the best path to take for VS.
  • new tool
    @monsterfox Got it. I will add this to the feature lists for 1.3
  • Blend Tool needs Split function
    Great, thanks for the input @Li-Xiao and for the effort @VectorStyler !
  • About half-tone
    @VectorStyler Look forward to a stronger VS.
  • Quick Adjustment of Swatches
    @debraspicher So this would be some sort of ""Palette Editor" view. Yes I think it is possible.
  • Multiple shortcut keys
    @monsterfox Sorry, I gave the wrong example (the number keys are fixed). So first remove the "S" shortcut (assigned to the Pattern tool), and then create for example "S X" for some tool and "S Y" for another tool. This should work.
  • New selection mode
    @Li-Xiao Thank you.I'll try it later.
    @Boldline I added this tot he backlog.
  • Create an action based on history
    @Subpath said in Create an action based on history: @Pat ... Because you can design without having a Script Recorder in Mind. That's exactly what I thought : we're "starting new adventures" with VS , we're enjoying the design and we'd like to record all steps quickly and easily. Two steps would be perfect: recording an action from the History panel and importing it from the Action panel ...
  • Integrated menu
    @Subpath You have a great plan, too. Thank you for your help.
  • Pen tool - fill shapes usability
    @VectorStyler said in Pen tool - fill shapes usability: @Ingolf said in Pen tool - fill shapes usability: I will try to find a solution for this. The context panel is a bit loaded for the pencil tool (npt much room left). This setting also applies to the pen tool, which is what I use the most and mentioned above, but in the settings, it says pencil tool, so it's extra difficult to guess what the setting covers. Yes, there's a lot going on in the interface, but perhaps you should consider using text labels less; they take up a lot of space and, of course, are easier to understand, but visually, they take up the equivalent of 4-5 small icons, and I think they create a cluttered interface. But anyway, I referred to the setting in the pen tool, but I would say the issue also applies to the use of the pencil tool. Cheers
  • Shortcut option to close shape when arc tool gets added
  • Layer panel customization after 1.2 changes
    C
    In any case, I find the color coding too wide, Illustrator has very nice narrow stripes.
