• How does arithmetic operations work in Transform panel?
    @Harry In the angle editor the units are just decorative. In the position / size the units always convert to [pt] and this causes the issues here. I will try to improve this.
  • Difficulty selecting small objects surrounded by others
    @VectorStyler I sent you the file by email. I was trying at first with the wacom stylus and then tried with mouse - it was easier with mouse but not by much
  • Align to Shape does not work as expected
    @VectorStyler works after convert to curve put i miss this Part here [image: 1669801829205-missing-part.png]
  • Repeat Move of nodes
    @Raven said in Repeat Move of nodes: then select other node/s and choose Repeat Move, the nodes move by the amount of the earlier object movement I think this might be a bug. I will try to replicate it and find a fix ASAP.
  • How do I switch back to text size preview when dragging with text tool?
    @b77 said in How do I switch back to text size preview when dragging with text tool?: That option enables text size preview when dragging and it's not working. ok - yes then we're on the same page. I wanted to be sure it was not just me who was having issues with it. Also wanted to be sure @VectorStyler was aware of the issue. thanks https://recordit.co/wWWD7odBwV
  • Improved Context menu bar
    @Jayanta-Das Some attribute options are only shown if there is a selected object.
    @Boldline Probably this problem existed before. The "Transform" is added to the text if it is scaled. But when converting to curves, it should keep the positions. Can this be replicated with the example sent by email?
  • Can merge nodes at center handle more than 2 nodes?
    @Boldline I will try to figure out how to make this work with more than 2 nodes.
  • Shift modifier for pulling node in single direction?
    @Boldline When multiple nodes are selected, this should work. For a single node, it depends on other modifier settings.
  • How to open multi page PDF on one canvas?
    @Harry Yes, pages are overlapped in this one. I will try to fix this as soon as possible.
  • Easy way to switch from a shape with two node points to one
    @VectorStyler ... and -at least on this test- the corner editor tool works very well ! you may not see it here but at the beginning, it was a rectangle which I rounded the corners [image: 1669651938534-cap-resized.jpg]
  • Could we reduce magnetic strength in half?
    @Boldline Will do so!
  • Moving clipped objects changes their shape
    @VectorStyler File sent.
  • Stroke mitre/overlap question
    Success. Excellent, thanks.
  • Object with two strokes, how to convert to curves ?
    @Pat Edit the stroke attributes or the shape? The stroke attributes can be edited in the Appearance panel: [image: 1669476567968-stroke.png] The shape cannot be edited separately. For that we instead should use the Offset Path live shape effect, and then convert to curves.
  • Transform Pivot Point Snapping
    @Igull said in Transform Pivot Point Snapping: I wonder if there is a preference on this that I might be missing No preference for this. I will try to find out what is the issue.
  • Distribute/Align Shapes Help
  • Object Style Preset
    @VectorStyler Yes its fill was set to zero, thats the effect I wanted. As I said after saving as preset I had tested the preset by applying to other shape and it was working ok.
  • Increasing the range of keyboard shortcuts by adding more keys
    Suggest looking to WordStar for inspiration.
  • New document setup - Why duplicates of the same data/parameters?
    @VectorStyler Well, I understand. In this case, why not remove the redundancies in the "Artboard options" window? It can be confusing to have all these different ways of changing/adjusting the same parameters whatever they are. It's not an issue, but at the beginning you always wonder if they are exactly the same settings.
