@VectorStyler said in Image Not Shown in PDF:
@gotanidea The Precision field (first export view - PDF Options) should be larger than 0, more like 2.
(should not allow 0 here, will fix this).
I see. Thanks Admin
@Bones Anti-aliasing can be turned off using View -> Subpixel -> None.
But it has only a small impact on redraw performance.
At what zoom level was this slowdown observed? and is it with the AI import or the SVG (results are different).
As for the AI file: some features are not (yet) supported, there will be improvement in the future.
@gotanidea said in Automatically Update Missing Links as in Adobe Illustrator:
I have to test this, but this should prompt for missing links.
Added this to the backlog.
@b77 Thanks - I like the location of this option better than where illustrator has it. Rotating the canvas and keeping the created vectors and such in a normal view can be great for certain things. I wonder if an option to keep the canvas in normal view and rotate the material created might also be a good option to add eventually in some capacity
@VectorStyler so far is always been a literal double tap, but I will try adding that function to a stylus button and see how that goes. I agree the stylus overall is less precise and using a stylus button might help in multiple ways
@VectorStyler said in How to Edit Text Background?:
@b77 @gotanidea The modal character options editor has a bug when working with background / underline and other decorators. Some drop downs don't open. The fix for these will be in the next build.
Good to know that. Thanks again
@VectorStyler Thanks for confirming there's a bug. Another issue that might be related is that the "Close Shapes" value in the "Shape Paint Options" dialog does not persist. It gets reset back to the same very small value whenever the dialog is closed and re-opened.
@b77 That's a slick workaround you came up with!
Ahh! That's what I was looking for!
I think I was thrown by the term "grid" since I usually think of the grid as a separate design guide element than the background.
Thanks!
@Boldline You didn't by any chance click the 'Favorite Font' entry in the Character panel's menu?
That is a checkmark, and if you click it, the font is deleted from the Favorites list.
