    • Scaling Strokes and Effects
      5526
      @vectoradmin Maybe the Spacebar can be coopted in the combination.
    • Modifier key after clicking mouse - right design choice?
      3348
      @Ingolf If there are cases that do not make sense, please report it!
    • Quicklook image preview of VS files not working?
      2433
      @Boldline Yes, there is an open issue with quicklook. It seems that on some systems, MacOS does not let the quicklook plugin fully load. This issue is in the backlog, I will try to replicate it. The EPS file preview should not be related.
      Size proportion lock in Shape and Properties panel
      2981
      @vectoradmin Thank you.
    • Image Trace - ability to choose what colors are traced and what is ignored/converted to another color?
      6569
      @Boldline @b77 I will add this to the backlog.
    • Shape is stretching in an unorthodox manner
      5356
      @Boldline I select the group (with the first selection mode in the context panel). The Shape Effects panel will show all the shape effects applied to it. This will be a Transform and a Warp. Click at the remove (x) icon at the end of the Warp row.
    • Convert symbol set to regular objects (finalize)
      6443
      @b77 Thank you.
    • Computer beeps at me when I use eyedropper tool to select color to apply to selection
      2632
      Maybe I'm doing something else wrong with the layers or a setting because it does not always happen - it's probably user error on my part
      Have had a Question about the Repeater Panel - is solved
      2134
      This topic is deleted!
      How to distribute objects with a precise distance between them ?
      33
      33
      42979
      I often use alignment in my schemes because I can have a lot of objects per artboard. Nice I can keep alignment options on, thanks for the tip @Boldline Why not just make the "Align selected objects..." functions independent of other parameters (e.g., space) since when we want to space the objects by a specific distance, @vectoradmin has implemented adhoc functions? So, with two clicks, the objects are at the right distance from each other and aligned. Isn't this redundant or am I missing something?
    • Eraser, Path Brush, etc. lack a true "rope" despite the feature being offered.
      2839
      @vectoradmin I could be wrong, but rope currently seems to act more like what I'd expect and see from "curvature" It reminds me a little of what is used in raster design programs to help get nice curves and line work - usually referred to as "streamline" where the stroke is immediately altered upon completion to be more smooth, etc. But yes, it would be awesome to use the actual rope in all the applicable tools, not just in the brush tool
    • Clicking on a node to move it does not always do so
      2573
      @Boldline I have to try to replicate it. It could be something to do with the click selection sensitivity. Send me the file with this shape by email.
    • V
      'Actual Size' is bigger than the actual size
      • vectoroid
      3382
      @vectoradmin It's the same on my 4K screen. I have it set at 150% (my eyes just aren't having it anymore). I know in Clip Studio Paint I have to fiddle with a ruler on screen to get the actual size (and have the app set to 160.4 dpi or some odd value, but it works really well.
    • R
      Converting layers or groups to Artboards
      • richbyte
      3598
      R
      Exported Successfully! @vectoradmin Thanks.
      Need some advice on pen pressure
      11951
      @Jayanta-Das Then this is still an open bug, it has been reported before.
    • Blend not showing result
      4616
      @Boldline I think the Contour effect might have the same bug.
    • I don't see artboard names on screen anymore after latest upgrade
      3454
      @Ingolf
    • Repeating a set of grouped shapes around a circle
      4847
      @Boldline There is already a plan for having a repeater type "along a path" that is dynamic (repeated objects are updated as the shape is changed).
    • Shape Paint -Am I missing a step?
      3015
      @vectoradmin ok glad it wasn't just me Do you need me to send you anything or are you able to replicate it?
