Snapping issue I faced
https://recordit.co/q1fPvVM3QL
I am getting hard time snapping object. Here you can clearly see that it is not snapping well. but it snap with bounding box instead. I dont know is this a bug so posting here. -
@Jayanta-Das What you need is Collision Snapping from the same panel, if I understand correctly.
@b77 OMG You saved me. Thank you.
A proper Tutorial is needed for me for some basic functions. Coming from another program so will take time. -
@Jayanta-Das 'Snap to Shape' snaps only nodes to object shapes.
@vectoradmin Can this be made clearer by changing the name to 'Snap Nodes/Points to Shape'. Or is it too much?
@b77 said in Snapping issue I faced:
I think its ok with the current name. Its just happening as there is no tutorial of functions. Once it comes to knowledge everything will be ok.
@Jayanta-Das There is a video about 'Collision Snapping' here: https://vimeo.com/322860084,
and one about 'Snap to Size References' here: https://vimeo.com/322860166 -
@b77 Thank you. I will have to check all the videos.
