    XY position of object
    14 Posts 5 Posters 12.2k Views 4 Watching
    • J Offline
      Jayanta Das
      Is this a bug? The XY position of the object should be the top left corner if the position is set to 0,0.
      Like this
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
      BoldlineB VectorStylerV 2 Replies Last reply Reply Quote 0
        Boldline @Jayanta Das
        @Jayanta-Das It's basing the location on the center-point of the design - the red dot in the middle of the rectangle. If you move that red dot to the upper left corner, it should do as you are wanting. I don't know if there is a setting for it to align based on exterior of the shape or the center-point
        • b77B Offline
          b77 @Boldline
          @Boldline said in XY position of object:
          Hmm… it doesn't. I guess the red dot is just the rotation pivot and nothing else, @vectoradmin ?
            Boldline @b77
            @b77 thanks for correcting me on that - I had thought I had done that successfully before, but maybe not.
              VectorStyler @Jayanta Das
              @Jayanta-Das The Properties and Transform panels have a knob for selecting the reference point of the object (just like in AD).
              b77B J 3 Replies Last reply Reply Quote 1
              • b77B Offline
                b77 @VectorStyler
                @vectoradmin It is too big and we didn't notice it. 🤦
                • J Offline
                  Jayanta Das @VectorStyler
                  @vectoradmin said in XY position of object:
                  Really I am blind.
                  Wacom Intuos Pro
                  • b77B Offline
                    b77 @VectorStyler
                    @vectoradmin Oh, btw…
                    It would be nice if the rotation pivot would display some orange crosshairs as visual confirmation when it snaps to any of the corners and sides of the bounding box, and if you move it back to the center.
                    • J Offline
                      Jayanta Das @b77
                      @b77 With the current most of the issues I encounter is resolved. The only improvement I would love to see in the next build is snapping.
                      Wacom Intuos Pro
                      • b77B Offline
                        b77 @Jayanta Das
                        @Jayanta-Das Better snapping in what way?
                        • J Offline
                          Jayanta Das @b77
                          @b77 Most of the time I find it's hard to snap to shape like when it is set to snap to shape. Sometime it doesn't indicate.
                          Wacom Intuos Pro
                          • J Offline
                            Jayanta Das @Jayanta Das
                            @Jayanta-Das said in XY position of object:
                            Or may be I am missing something in the setting.
                            Wacom Intuos Pro
                            • b77B Offline
                              b77 @Jayanta Das
                              @Jayanta-Das Record the screen to explain exactly what the issue is and send it and the test file to the developer by email.
                              • J Offline
                                Jono
                                Just to add something in relation to the original post, you can change the ‘top-down coordinates (to match the second screenshot) in the document setup options.
                                Mac mini (M1, 2020) | Tahoe 26.1 | Wacom Cintiq 16 (1920 x 1080 px)
