      Is it possible to reset all object's content / properties to default with one click?
      2814
      @VectorStyler Thanks - the "X" icon is what I was looking for. The simplest things are most often the hardest to find
      Applying Paragraph Presets
      • Kumr
      2305
      @Kumr I opened a bug on this and will try to replicate it.
    • How can I edit the size of rotated text box?
      3141
      @Raaskot The text box seems to have 2 transformations. The Shape Effects panel contains these transformations and can be individually removed there also.
    • How to restore the default settings for keyboard shortcuts
      3637
      Yes, that would be nice. Thank you.
    • Live text that is modified and copied and then pasted over text on path does not retain edits
      5372
      @Boldline said in Live text that is modified and copied and then pasted over text on path does not retain edits: would I need to alter it in the appearance panel instead? I think this this case you need to use a character scaling option from the Character Panel (expanded mode of the panel). Also, there is a Settings that changes the character scaling when scaled with the Transform tool.
    • C
      Coordinates top-down direction as default?
      • creative
      1985
      @creative When you create a new document with the "New Document Setup", all the settings changed there will be defaults. There is a "More Options" button on the right side, if you scroll down.
    • C
      Creating and using guideline groups?
      • creative
      5395
      C
      @VectorStyler said in Creating and using guideline groups?: I think what is needed here is document templates. Just set up a new document with guidelines and everything else needed, and then save it and use it as a template with the New Document Setup. Thank you very much, that's probably the best way. With so many great features and functions in VectorStyler, it's easy to lose track.
    • C
      Document presets backup?
      • creative
      2787
      C
      Mac, I looked at the reveal workspace but include those files there the dozens of new document presets I created? The Presets Manager seems to be the better way.
    • Disabling path brush strokes from joining
      • Daniel
      3834
      Thanks very much! I will try this and let you know.
    • T
      VS now crashing after settings change
      • Tonyrambler
      4592
      @Tonyrambler It should work now. I had the same issue with my previous MacBook and choosing "Metal" was the solution.
      Controlled thick and thin lines
      • Jackamus
      5418
      @Jackamus said in Controlled thick and thin lines: How do I draw a new ellipse without any previous attributes? In VS the previous attributes are used when drawing new objects. In this case you can clear the width profile on the new object by clicking the solid stroke icon in the stroke panel (second from last).
    • VS startup time
      28
      28
      30921
      @Harry said in VS startup time: Where are the temporary files located in Windows? It is up to the operating system to serve the temporary file locations and this may vary between versions. VS will still clean the temporary files, but it does so after crashes, and not at startups. With normal exit, VS will not leave temporary files.
    • Rotating linked vector files
      • chessboard
      3219
      @chessboard This issue should be fixed in the new build 1.2.018
    • C
      How to create own document preset groups?
      • creative
      2073
      @creative The current "New Document" view cannot define new groups of presets. It will list all document optins presets in a single flat list. I will improve this ASAP.
    • PDF X
      • michaelokraj
      3302
      @michaelokraj I will add a separate PDF/X export before 1.3
    • C
      Changing tooltip font size?
      • creative
      2066
      @creative Tooltips are handled by MacOS.
    • Why is it so much easier to select a clipped object outside the shape than overtop the main shape
      3169
      @Boldline Use the "Isolate Inside" (double click) to edit the content of a group. I changed the order of the selection (members first) for the next build (it is just a resource flag), lets see how it will work.
      How to convert pattern to shapes?
      • maarten
      2968
      Thanks for the quick response. Ah, I did try that but silly me; I didn't see that what was generated was actually a group with all vectors inside. Sorry for that. Nice to see it's possible. Have a nice weekend!
      Regarding the issue with the applied effect of the Repeater
      • Li Xiao
      4163
      @VectorStyler Understood. If there could be a simulated expansion, it would solve this problem by preserving the non-destructive effects and applying the final effect to gradient content after the Repeater.
      Adding white noise to a specific color in a color gradient
      22
      22
      24824
      @VectorStyler Thank you That's what I was doing but had forgotten about this single/double click... hence my lack of understanding.
