    3. VectorStyler 1.2 beta
      Bug : No Preview and Crash on "Add new nodes ...." Feature
      3604
      @Li-Xiao said in Bug : No Preview and Crash on "Add new nodes ...." Feature: @Subpath your welcome. I previously bought a macro for CorelDRAW and it has some nice node-related features. http://gdgmacros.com/details.php?prodId=286&category=14 It's a pity, it has stopped updating. Looks interesting As far as I know, CorelDraw has a scripting part. The last time I used this it was Visual Basic, so if some are a little adventurous Btw Scripting is also on the Roadmap of VectorStyler.
    • beta update 1.2.002
      • VectorStyler
      21
      21
      25436
      @VectorStyler I mistakenly set the video private. It is now for public viewing. Please check.
    • UI Theme [Light Grey]
      1736
      @861475_VctSt said in UI Theme [Light Grey]: If you can revert to the original color scheme, please consider it. I will check what changed here. Should be easy to revert.
    • Quick look Preview
      1998
      @861475_VctSt Yes, this is still an open bug.
    • Move it by ⇧+→.
      2693
      @861475_VctSt Got it. Looks like the percentage value is read as 10 pt (not 10x). This is a bug, will be fixed in the as soon as possible.
    • Show center point of object
      2007
      @VectorStyler Thanks You made it easy.
      Issue with the Variable data export
      • Li Xiao
      3394
      @Li-Xiao said in Issue with the Variable data export: Actually, all of about exporting variable data is problematic. Opened a bug on this one.
      Missing links and files in the documentation (docs_v1_2)
      • freggern
      2538
      @freggern Fixed.
    • Toolbox Customisation - arghhhhhh!!!
      1760
      @Igull This is the same as before. The problem is that those toolbox "modes" in the menu are actually different toolbox customization presets that will overwrite the current (unsaved) toolbox. I will try to think of a better solution for this.
    • Keyboard Shortcut(s) Broken
      3074
      @Igull Looks like there is still one issue: the app needs a restart to have the shortcut show in the tool tip. I opened a bug on this one. I will test the toolbox thing also, the problem is that 1.2 has a lot of new tools.
    • Rectangle and oval tool amongst others, are again warping when pulled with the transform tool.
      2110
      @Boldline The stroke width is scaled (a document level option) and it is not scaled uniformly.
      Trim and Join Tool - bug?
      2112
      @Harry Added this to the backlog, looks like a bug.
      Question, how to "Convert Dashes to Curve" ?
      2596
      @VectorStyler , thanks Have overlooked this arrow and the option below it. Thought the arrow might be a bit more prominent ? Hadn't guessed that the option was under Object > Shape. I was looking/searching in the brush stroke panel. But cool to have that option
      Not enough options in "Arrange Artboards" panel
      1605
      @Harry Added this to the backlog.
      Issue with the Shape builder tool
      3741
      @VectorStyler File sent. Two rectangles induce the issue (showed by arrows)
    • Setting the font size by dragging the mouse does not work.
      2915
      @encart Pressing Alt first and then pressing+dragging the mouse works here.
    • Editing vector mask inside transform>mask>drawing has location paste discrepancy
      1828
      Old problem with long paths is back in 1.2
      3440
      @Boldline said in Old problem with long paths is back in 1.2: @VectorStyler is it worth keeping your overall mode as an option? I think it might be. In some cases it could be important to see the precise shape of the erased area. Same goes for the path brush.
      Issue with the Blend panel
      4105
      @Pat I opened a bug on this one.
      Issue with stroke profile
      4487
      @VectorStyler You can try with the file I sent you.
