    Is there a way to know when stroke handle is aligned with stroke angle?
    13 Posts 4 Posters 16.5k Views 2 Watching
    • b77B Offline
      b77 @Boldline
      But I would prefer to know if the node is cusp, smooth or symmetric without having to select it.
      Maybe the simplest solution would be using different shapes for each node type β€” it's been suggested already here:
      https://www.vectorstyler.com/forum/topic/515/option-to-customize-and-assign-each-node-type-a-different-shape-indicator
      Something like a circle for smooth, a square for cusp and… what else for a symmetric node? A diamond?
      So if I see a round node (smooth) at the end of a straight line, I know that its handle is aligned with the angle of that segment.
      (There's also the start node β€” it still needs to have something like an arrow to indicate the path direction).
        @Boldline Select the node and make it smooth (button in context panel).
        There is a feature request to indicate node types by shape (and make it customizable), I will move it to higher priority.
        BoldlineB 2 Replies Last reply Reply Quote 2
          @vectoradmin I was not actively looking for this, but when I was using Affinity Designer tonight, I noticed they highlight the node when the handle is aligned perfectly with the other side. You can see it in the video here. The second one I did in the video shows the effect. I think that could work for VS as well - it's subtle but gets the job done
            @vectoradmin said in Is there a way to know when stroke handle is aligned with stroke angle?:
            I think this would also be a good improvement as well. so long as the shapes used are pretty basic - circle, square, triangle?
              @Boldline There will be circle, square or triangle shapes only.
              V 1 Reply Last reply Reply Quote 0
              • V Offline
                Vector-Rock @VectorStyler
                @vectoradmin
                As mentioned in my original post, CorelDRAW offers six (6) Preset Shapes that can be assigned to Cusp, Smooth or Symmetrical in any combination:
                • Square
                • Circle
                • Triangle
                • Diamond
                • Pentagon
                • Square with Rounded Corners
                Having six choices is probably overkill for most.
                The Diamond Shape seems like it might be popular for many?
                As @b77 mentioned, I can see people using the Diamond shape for Symmetrical. You may want to consider that as a fourth option as well. Especially considering the Triangle is used to indicate Direction of the Path and also to add Nodes to a Selection with Shift-Click. Something to ponder.
                VectorStylerV 2 Replies Last reply Reply Quote 2
                  VectorStyler @Vector-Rock
                  @Vector-Rock Those shape will be available when customizing.
                    Boldline @Boldline
                    @Boldline said in Is there a way to know when stroke handle is aligned with stroke angle?:
                    Did you have a thought on this alignment indicator like in Affinity @vectoradmin ?
                    Or were you implying this might be dealt with when you add the customizable shapes? I liked the idea that the node would change color when the path is aligned with the opposing size (only while you were moving the line itself, not forever)
                      @Boldline This will be dealt with when adding the shape customization.
                        @Vector-Rock Node shape customization is available now in 1.1.002 (beta)
