These features and ideas have been implemented in VS as suggested
180
Topics
1206
@Ayo said in About the Snap feature:
Wouldn't it be better to change "Snap to Visible Only" to "Snap to View Extend Only" or shorter "Snap to Viewport Only" or even shorter "Snap to View Only" ?
There is a big chance of confusion with the term 'visible' which is mainly linked to the layer system.
I added this to the backlog.
@monsterfox said in VectorStyler roadmap:
@VectorStyler These plans probably in how much time can be completed?
Cannot make a commitment on that, but it is in years (up to version 2).
@VectorStyler The following error is included in the file I provided. Selecting the red circle inside will result in the selection of the outer graphic.
@VectorStyler My suggestion is to add an option called "Reverse Transformation" in the transform menu, with customizable shortcut keys for quick access. Thanks for adding this feature!
@FastVector
i think i see it, adding a Node doesnt work when you
activate the Node Tool with the Control Key.
Your are right its the same here.
Seems if you activate the Node Tool with the Control Key
that the Node Tool its a bit limited then.
Adding a Node works only by selecting the Node Tool
direct.
@Daniel You've done an awesome job discussing the tools, the Bezigon tool especially! I've learned a ton of information from you on all this and I appreciate your dedication to helping everyone understand better. I'm sure @VectorStyler has a good sense of what you're talking about and when he gets the opportunity to add it, we can go deeper with it and see if there are improvements to be made, etc.
@VectorStyler thanks! Also, sometimes when I am selecting colors on the left side, VS does not always let me select them - they don't always get highlighted, I think in part because some might have multiple colors inside the grouping? Would it make sense to add a button on the left side of the colors that could be clicked on or off to highlight the color?
