An Idea for improving menu navigation
Is it possible to add a delay ( e.g. 0.5s) before the menu level closes? Currently, to get to an item from the next menu level you have to follow the menu items precisely ( red arrows). If the menu didn't react so instantly , it would be possible to do it faster and wouldn't require such precision.
@encart I will try to add this
1+ from me for that
have the same problem here
you need be careful precisely horizontal
I often slipped a little and the menu is gone
Thank you for the changes you have made. I am invariably amazed at the speed with which you make them.
I only have one comment. I would add some small delay (100ms?) before the menu is displayed. Now, when I move the cursor over the menu, the next level is displayed, but it is not always the one I want and I have to wait 0.5s before it disappears.
https://go.screenpal.com/watch/cT1DoNnXUr2Edit: Just discovered a bug.
Any item clicked with mouse displays second copy of menu.
Clicking on menu items should bypass the delay I mentioned above and display the menu immediately?
@encart I will try to fix this ASAP.
