Simplify undos
Would it be possible to simplify the way undo works? When I have an object and I transform it, then switch tools but decide I want to undo the transformation, I have to go through all the small steps of the transformation, instead of simply going back to the state before the transformation. Though I can imagine this being useful in some situations, it is not ideal for my needs and I would prefer a simpler approach, perhaps as a preferences option?
@postdes Added to the backlog. It might result in an option, as undoing all effect changes at once may not be suitable in all cases.
In build 194:
Undo resolution for shape and image effect editors, can be enabled and adjusted in Preferences -> Changing Options -> Merge ... check boxes and number fields (for timing between captured changes).
Much better, thanks!
