• Style Picker with Group dont work as expected
    And of course it works even with colors [image: 1770308106217-with-colors.png]
  • Main site font is Times New Roman
    @VectorStyler said in Main site font is Times New Roman: @Ingolf I will try to fix this Seems to be fixed now! [image: 1770224809989-84921ea5-3b3b-49c4-b05e-68f2f23f34f8-image.png]
  • increasing the arrow-up-down key steps in the standard numeric field
    @Raaskot said in increasing the arrow-up-down key steps in the standard numeric field: Hence my wish to adjust the steps further up in Settings. I will add this as a feature later
  • VS don't respect Mac system Number format
    @Raaskot I will open a bug on this. Could also be affected by the system level language selection (here it is English).
  • Improving the Drop Shadow tool
    drop shadow
    @Boldline said in Improving the Drop Shadow tool: The other issue is when I switch over to the drop shadow dedicated panel, whatever settings I made using the toolbar tool just prior get negated. After I adjust settings in the drop shadow panel, if I click "ok" it reverts back to whatever was set on the toolbar option and I lose all edits in the drop shadow panel. I will try to replicate this
  • code d'accès
    @cha A trial code was sent yo your email address. Enter the email and the code in the trial startup view: [image: 1769670112336-trialcode.png]
  • Queries Regarding VectorStyler 1.3
    59
    @monsterfox said in Queries Regarding VectorStyler 1.3: could the save operation be designed to take effect only upon full completion This this is doable. I will open a bug on this and do it as soon as possible.
  • Text acts strange in column -- huge gap
    @Raaskot Replicated, this is a bug.
    @Subpath The sketching option is wrong now, I will try to find a solution for this.
  • How to copy or duplicate a path in a mask
    @VectorStyler EDIT: Ah, I understand now: you meant the functions under Edit-->Attributes. I didn't know of these yet I think the procedure is still cumbersome in comparison as stated below. Also I get an unintended offset. I dont know if I understand you, but if I replicate your suggestion stepwise it does not produce a new path on top of a mask and the masked elements. Sorry for referring til AI; it's makes it perhaps a bit unclear: AI: When I select a shape (the mask)with select tool (A), change tol select tool (V) and thus paste in front (cmd-F) I'll achieve what I want: a duplicate on top. This also goes for grouped shapes/objects and is useful for fast editing of effects exactly on top of an existing visual element.
  • Import svg patterns
    @VectorStyler said in Import svg patterns: The object that was filled with the pattern is large and when expanding creates a lot of small clipping groups. This is slow to render for now. Thanks for checking on this. Yes, the pattern has a lot of objects but it looks like imported patterns are expanded using more nested clipping group layers than patterns created within VS. If the pattern expansion could be improved to remove un-necessary grouping, it could improve performance
  • Spell Checker
    @William-Kansepa said in Spell Checker: @VectorStyler thank you, the Spell Checker is now working! Question: Is it possible to improve the Spell Checker such that it automatically highlights or underlines and displays the misspelt word in the Error input box? Also to have the most likely suggestion showing at the top in the Suggestions input box? Pressing the "Next" button should highlight the next word and bring it into the error field, also in this case a suggestion (if exists) is shown.
  • I would like to make a brush... a simple brush
    28
    34k Views
    @FanVidder I don't find the basic steps all that complicated. CorelDraw was my main application before VS, i know a few other vector graphic apps too. It took me a while to get used to the new terminology. It might look complicated, and some functions are harder to understand. Just take your time and go step by step. Yes, there aren't many tutorials on YouTube, probably due to the still small user base. I do post tutorials here in the forum from time to time, but I have no interest in dealing with YouTube; it's just too much effort. The best thing to do is search the forum, check out the tutorial section, or simply ask.
  • Snapping when dragging multiple nodes
    @monsterfox said in Snapping when dragging multiple nodes: Could the issue of snapping an object to a specific point when dragging be fixed as well? The next build will solve this issue in a bit different way: all dragged points will snap. I will release this first.
  • Which specific VS setting for printing horisontal pages?
    @Raaskot I will try to replicate these
  • Difficulty with selecting Guidelines
    @VectorStyler said in Difficulty with selecting Guidelines: @Boldline Send me a file where guidelines are difficult to select. About the Layers panel, guidelines will not be selectable here as they are not objects (these are objects in Illustrator). A guideline can also be selected (turn red) by selecting it in the Guidelines panel. Just emailed you the file. I understand the selection option in the layers panel will not work for the guides, I was suggesting that the same principal feature be added to the gudies panel - where you can select the guide by clicking on a similar circle added to the guides panel. You mentioned here that the user should be able to click on the guide itself in the guide panel and have the corresponding guide be activated on the canvas, but that is not working for me. When I click on the guide in the guide panel, nothing activates.
  • Adding modifiers in attached file have no effect
    @Raaskot said in Adding modifiers in attached file have no effect: Masks are not affected. Bug or by design? I tested this, and unfortunately this is by design. The Halftone effect will work on the image part only, not the mask. This case can only be handled with vector halftones
  • Redrawing part of a path with the pencil tool
    @Raven said in Redrawing part of a path with the pencil tool: I haven't been able to get VS's Liquify tool to act the same. I added the Freeform tool to the 1.4 feature backlog
    @Raven Cannot be disabled, I will try to fix this for the next build
  • Stroke width of imported svg
    @EricP There is an SVG importing bug here, I have to find a solution.
