• Why is Display Options shown when selecting Export → Options?
    @nocturnalYL It is the title the view, the same options used in display. I will change it.
  • Does VectorStyler support HDR displays?
    @nocturnalYL If youn have a HDR display, try the 16-Bit/Component mode in the View -> Display Options -> Color -> Precision field. EDIT: but it does not support HDR rendering (the color domains are different in HDR).
    @VectorStyler said in Missing Core DTP Layout Markers for "Text > Insert Character" (v1.3.020): I will add these to the features backlog (will need a bit more that just inserting the character). Understood. I see now that my understanding was a bit simple—this request isn't just about inserting a character, but about inputting a trigger to control the layout engine itself. UI-wise, this means it belongs under something like "Text > Layout Control" (which doesn't exist yet) rather than "Text > Insert Character." No wonder it takes a lot of heavy lifting under the hood! Since I couldn’t find them even after a thorough search, I now understand why they weren't implemented even as hidden features. Thank you for adding them to the backlog. Looking forward to it! Best regards,
  • maintain layer structure and names when exporting to PDF?
    @Raaskot said in maintain layer structure and names when exporting to PDF?: layer/OCG export Not exporting (only importing)
    mackotomiM
    @VectorStyler Thanks!
    mackotomiM
    @VectorStyler Thank you so much!
  • how do I create a new object or path in a selected sub layer?
    @Li-Xiao Great. What I was looking for.
  • ISOMETRIC PRESETS
    @ZATOPEK Hi in case you dont know there are some tutorials which may be helpful @devil-dinosaur did some Tutorials. https://www.vectorstyler.com/forum/topic/1648/isometric-drawing https://www.vectorstyler.com/forum/topic/2063/isometric-drawing-tutorial and @pentool did also some https://www.vectorstyler.com/forum/topic/3334/axonometric-transform-actions https://www.vectorstyler.com/forum/topic/4650/easy-axonometric-piping-tutorial
  • window often shakes
    @macos said in window often shakes: UI English + Font Names Chinese, Do we have this option? No such option
  • Selecting multiple areas without excluding overlapping parts
    @debraspicher Wow! Thank you for sharing with such depth into your recording setup and process. I have a program called "Screenflow" that I use for recording tutorials and regular screen videos. I had not thought of using OBS as a way to record regular use video to look back on for an issue. Seems like it would be less intrusive as I could set the controls and view screen on a 2nd monitor. I will try it out and get back to you if I have any questions! thanks again
  • Stroke scaling
    @macos Send me an example file with this issue
  • Want new objects with brush outline
    @Raaskot These parametric shapes cannot be create with brush outline. You have to select it afterwards. Those settings work for Pen and Pencil only. I will add an option for this.
  • Scaling results
    @macos I opened a bug on this
  • Enhanced Blend Tool Function
    @Boldline ... I had come across Graphite app a year ago or so and was impressed by some of the ways they were handling vector tools; The focus on non-destructive vector editing as it relates to the unique mind mapping editing map. ... I totally get this. I, too, appreciate apps that take unconventional approaches. Btw. that one of the reason i bought Vectorstyler Even though I don't use Graphite myself, I've still followed its development from time to time. For instance, there's a dedicated thread about it on the Blender forum. I really came to appreciate the possibilities that nodes offer for creating vector graphics—if not sooner, then certainly after I started working with the app NodeBox. Patternodes, for example, also utilizes nodes.
  • Temporarily disable snapping
    @VectorStyler said in Temporarily disable snapping: @William-Kansepa on Windows should be the Control key, but you must press it after the moving started @VectorStyler Thank you so much! It's working as expected.
  • An UI question, selecting objects in layer panel list
    @VectorStyler Cool. What I looked for. Thanks
  • Clipping group produces transparency artefacts
    @Raaskot It seems to be a bug. workaround: turn on the "Path" object "Isolated" option in object options
  • crop vector
    @ZATOPEK That is used for images only. You can use shape Intersection for this
  • Replace Colors feature is doubling instead of merging down colors
    @VectorStyler Thanks! just emailed you the file
  • Text frames, please tell me the difference ...
    @Raaskot Can you send me the workspace and settings files to my email address. Something is different here.
