    How to copy or duplicate a path in a mask
    3 Posts 2 Posters 10 Views 2 Watching
    • RaaskotR Offline
      Raaskot
      I frequently need to copy or duplicate a mask path on top of a masked group. This is useful when modifying the path without changing the mask. If I just copy and paste it returns nothing unless I copy mask and masked object together and delete the surplus. It's a bit tedious when doing this often.
      Would it be possible to do this like in Adobe AI or is there a setting I missed?
        VectorStyler @Raaskot
        @Raaskot Copy Shape and Paste Shape.
        First use Copy Shape on the clipped group.
        Then draw a new object (can be a rectangle) and use Paste Shape.
        How is this done in Adobe ?
        RaaskotR 1 Reply Last reply Reply Quote 1
        • RaaskotR Offline
          Raaskot @VectorStyler
          EDIT: Ah, I understand now: you meant the functions under Edit-->Attributes. I didn't know of these yet I think the procedure is still cumbersome in comparison as stated below. Also I get an unintended offset.
          I dont know if I understand you, but if I replicate your suggestion stepwise it does not produce a new path on top of a mask and the masked elements.
          Sorry for referring til AI; it's makes it perhaps a bit unclear:
          AI: When I select a shape (the mask)with select tool (A), change tol select tool (V) and thus paste in front (cmd-F) I'll achieve what I want: a duplicate on top. This also goes for grouped shapes/objects and is useful for fast editing of effects exactly on top of an existing visual element.
