      Text Tool and Area Text Tool - Cannot Cut and Paste
      • KF
      8599
      @KF The above steps work here (on Windows). I have to investigate this further. There have been reports of issues with Windows clipboard before.
      Minimalizable Panel Windows
      3600
      @Boldline Thank you, you understood me correctly. That's cool that it's already possible in VS. Kind of a hidden Feature, because there is no visual indicator that this is possible
      Resolution Matters
      • KF
      3510
      @vectoradmin Thank you for your hard work. Appreciated. Best regards, KF
      Distributing nodes equally along a line.
      • Gremriel
      21
      21
      31147
      @Jono me too
    • Option to auto close all selected open shapes, etc
      3020
      @Boldline In the Path panel, second row third icon should close individual paths without joining them.
      Any mirror function in VectorStyler ?
      • KF
      12779
      @vectoradmin Thanks for your explanation. Will study it when I have a little more time.
      Outline stroke
      • William Kansepa
      5580
      @b77 said in Outline stroke: @William-Kansepa For what you asked in the original question, use 'Expand Stroke' from the Styles menu. Thank you so much @b77. This is exactly what I was looking for. Thanks to Numeric Path for coming out with an unorthodox program. It definitely keeps us on our toes. After tons of years on an Adobe diet, I am having to unlearn a LOT of things.
      Can avoid pixelated graphic if export the vector graphic to PNG or JPEG?
      • KF
      4181
      @KF But, if you need vectors after export, use PDF or SVG formats. With some exceptions (image effects), these will have vectors.
      Delete saved pattern from preset
      • KF
      4794
      @vectoradmin Hello, I have delete the pattern. Thank you for help.
      Will presets slow down the software loading time and performance
      • KF
      4499
      @KF No need to avoid it just let me know if something slows down, and will treat it as a bug.
    • Bendy Arc warp
      • Dazmondo
      13748
      For more details on the bendy logo see: https://www.vectorstyler.com/forum/topic/939/bending-logos-accurately-around-a-curve-for-a-vinyl-lp-label
      Offset command adding too many nodes/anchor points
      • William Kansepa
      4751
      @vectoradmin said in Offset command adding too many nodes/anchor points: @William-Kansepa Were these offsets created in a single step (by setting the Steps field to more than 1) or in multiple steps? Sometimes it is better to do in a single step, because then all offsets are created from the outer shape. When the offsets are not uniform (as in the above case), then it is still better to create each from the outer shape, by increasing the Distance value. When an offset is created from an offset, this may result in more nodes than needed. I add this to the backlog as a task to improve repeated offset precision and avoid adding too many nodes (or maybe an option to keep the node count). The nature of the design requires that this be done using single steps to maintain precision.
    • "Align to" Reverts back to Selection Bounding Box each time
      5810
      @Boldline That explains why I could not replicate it. I was using the panel (not the popup). Now the root cause is clear, and it will be fixed.
    • Should text layers auto update name if text is altered?
      3264
      @Boldline They should auto update. I tried to replicate this, and here the name in layers panel changes with the text (even added some shape effects, to make it the same.)
      Antivirus Issues?
      • mainstreet1612
      3932
      @mainstreet1612 I'm glad that all got worked out!
    • What would be the best way to warp several lines at one time?
      3394
      @Boldline Hi I would use "Blend" for this and then refine it with the "Corner Editor" Tool This way you would also have better control
    • V
      Duplicate object at the exact position
      • valak
      3270
      @b77 thanks for your quick response
    • Path Brush sometimes only works when stroke overlaps existing path brush fill
      2890
      @Boldline Replicated! Will be fixed. It seems that after adding to some existing object and then starting a new one does not refresh after the paint. Command+R refresh will fix this.
    • condensing file name extension
      3565
      @vectoradmin sounds good on both - do what is most affordable so VS can keep growing and getting better known
    • Grid Opacity resets with each new document
      3119
      @Boldline I will try to fix this. It is not a bug, but the consequence of how grids / guidelines are working. The default document grid is inherited by future documents, but when the opacity is changed, the change affects the current canvas only, which is not inherited.
