      Gradient Mask Editor - Reverse The Transparency Points
      • KF
      3719
      Thank you.
    • value of even-odd fill/winding fill
      4275
      @Boldline AI also has this but I think the default there is Winding. Once the winding fill mode is set for a shape (Appearance panel, or Object -> Content -> Winding Fill), the new shapes will be drawn with it. I think there could be a preferences for having it on by default.
    • Controlling nodes and handles when deleting nodes to fill in a gap
      8095
      @Boldline There is an option: Prferences -> Editing Options -> Adjust Node Removal Curvature, that will not approximate the original curve when removing a node.
    • Clicking on gradient bar with shape selected transfers gradient settings to shape
      2947
      @Boldline Can be implemented, added to the backlog. Attached the file here: gradientidea1.vstyler
    • Alt/option key + click and drag creates new gradient color stop
      2851
    • Stray gradient presets outside their folder?
      3268
      @Boldline When creating new presets, these are added to the root of the group (specific to the preset type). The Panels -> Presets -> Presets panel, or the Styles -> Preset Manager view can be used to place these into folders, or to create new folders.
      Remove gradient point
      • KF
      3484
      Thank you.
    • Do not auto-open duplicated layers
      3162
      @Boldline This can be replicated, added it to the backlog.
    • Show selection with transform tool/etc
      3051
      @Boldline If I understand correctly, I think you need to enable 'Show Nodes of Selected Shapes' in Preferences > Editing Options.
      Just like to mention, VS Price tag was absolutely ok for me
      2491
      New user, must say how deeply impressed I am
      2833
      @Subpath2 Thanks!
    • Can we import Affinity Designer brushes?
      4000
      Hi @Boldline The Reason while you can not import Affinity Designer Brushes may also be , that only one Brush in Affinity Designer is a real Vector Brush. The others are Bitmaps along a Vector Path.
    • How do I get text to fill an existing shape?
      16418
      @vectoradmin i just sent you the file and an explanation. Basically the left side of the sunglasses were initially a copy and flip of the right side. So everything on the left side will be in reverse I assume - based on other discussions in the forum about that. Maybe the solution here is I need to flip the path direction?
    • Image trace number of colors slider
      4093
      @Boldline @b77 added to the backlog!
    • How to change layer name without opeing layer panel?
      13105
      @vectoradmin I'm using only mouse now. In Canvas&Artboard / Styles panel both methods are working - two clicks & Return key. Non of them work in Layers panel. https://recordit.co/nxTCRjltyt
      Convert Photo Image To Vector - White Edge On Each Shape Of The Vector
      • KF
      9355
      @KF Thanks for the image. I tested it, and with anti aliasing turned off (View -> Subpixel -> None) here is what I get: The anti-aliasing artifact is in the backlog (list of things to fix), and I will try to find a solution for that.
      Pencil line colour question
      • Jono
      4346
      @vectoradmin Thank you that's brilliant. @Boldline Thank you, that's a great tip.
    • Help needed.The position of objects relative to the last selected obejct
      3250
      @encart For this, you must align to a key object, and specify the key object by clicking: steps from the video: https://recordit.co/R83pZ7gBOA select the objects select key object mode (second in the left group at the panel bottom). click on the key object, in this case object 3 on your picture. click the alignment buttons.
    • Copy attributes
      2944
      @Boldline There is no eyedropper tool for character style, but the Copy / Paste Character Style in the Edit -> Attributes menu should help with this. For other attributes (like fill, outline, etc) the eyedropper tool should work.
    • Toggling pressure setting for eraser brush
      4012
      @vectoradmin Wow! I love it! I was not even thinking about an eraser options panel pop up - I love the control and settings it has. thank you
