      No size difference between a document with embedded images and one with linked images
      • William Kansepa
      6132
      @vectoradmin Thank you so much. That was a prompt response to the challenge. Yes, linking vs embedding is now working as expected. The size for the document with linked images is now significantly smaller.
    • Option to evenly auto-divide a shape vertically or horizontally
      9224
      @vectoradmin oh ok that makes sense. So many potential options to customize like that
    • Shape builder tool not joining some sections - deletes others
      3948
      @Boldline These issues should be fixed in build 1.0.055
    • Draw the shape from the center.
      3513
      Thank you. It's a subtle way of timing. I hope it works for square selection.
    • I invert the fill and stroke colors accidentally, but don't know how.
      4738
      @vectoradmin I'll take a look at it. That's possible.
    • Support on a feature: Distortion of a grid / swarm-like pattern without distorting the elements within the grid
      • michaelokraj
      7498
      Oh wow. That is helpful. Before I asked here at the forum I checked all the tools / filters / brushes but didn't come up on double clicking the icon. I don't know how Adobe is doing right now, but Macromedia Freehand and Fireworks had a little indicator within the tool icon where you could double click it when there was a "options"-menu available to be opened. maybe a suggestion for the toolbox-face-lift? Once again: thank you a lot for that support. It was such a time saver!!!
      Forum related Question
      4036
      @Subpath I would think as many relevant helpful ideas, suggestions and helpful posts as you want to share would be welcomed. It helps a lot when topics are separate threads because I bookmark relevant answers to questions and often go through the history of threads before asking a question - or I know the question was already asked before and I can go find my answer directly
    • New artboard setting show pts instead of preset unit of measurement
      3048
      @Boldline This looks like some sort of bug. I will have to replicate it.
      VS Installer should take File path of already installed version
      6400
      @vectoradmin Thanks, take your time. It would be nice, but its not so important for me.
      Idea for the Path brush tool
      5189
      @Boldline thanks for the tip
    • [Pattern Brush Preset] Parts of brushes are premanently linked with symbols.
      4414
      @encart The problems is that the pattern content uses symbols linking into the document. This is by design for symbols. Maybe when creating Presets maybe these symbols should be detached (copied) and not linked? Meanwhile a workaround. How were those symbols created? There are three ways to create symbols in VS: setting the object name and role (will be linked). creating from an object in the Symbols panel (will be linked). creating in the Presets panel (will not be linked). This one should be used for presets.
    • File size limit to upload on forum?
      3287
      @Boldline Looks like some NodeBB limitation. The settings is to allow up 4MB file size. But that does not work. Maybe link it with dropbox, or some other file sharing site, until I find a solution.
      OpenCL Vs Software ? On Win 10
      3729
      @vectoradmin , Thank you for your, as always, clear and well described explanation of how "CL" and "software" works.
    • Selecting node handles is difficult at certain zoom levels
      5277
      @Boldline I think this could be caused by the curve control point being too close to the node.
    • Option to not auto connect nearby brush strokes when second stroke is made?
      3542
      @encart @Boldline For me at least the Esc works. But there is also a Preferences -> Changing Options -> Don't Extend with Pencil that can be checked to skip extension even if selected.
    • Can split text be made to work with text boxes - not just text point?
      3787
      @vectoradmin Good question I would think point text
      Double clicking selected object query
      • Jono
      4208
      Thanks for the info, that's clever. I'm going to use that a lot now!
      New user, i stuck with a simple thing
      27
      27
      43845
      @vectoradmin , thanks a lot already downloaded
    • Drag panel from any part of top bar
      2624
    • Collapsed panels stay collapsed when moved around inside VS
      2703
      @Boldline This is in the backlog.
