    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
      None Fill - %50 black
      • hbalcic
      3866
      @hbalcic said in None Fill - %50 black: Swatches This term was introduced by Adobe and copied by Affinity and it refers to a mix of color, gradient and pattern definitions. VS choose not to use this because in VS the palette is just a color palette, with only colors allowed. For other things (mix of colors, gradients, patterns, etc) you have the "Presets" in VS (and also the "Styles").
      About the concealed pallets
      • hbalcic
      4077
      @hbalcic said in About the concealed pallets: It does not hide the palettes inside the window. This is by design. It is only mean to hide floating panels.
      Abnormal path.
      • monsterfox
      2610
      @monsterfox The stroke is expanded because it has a width profile (small variation). If you open the stroke panel and click on the width profile editing button, you can see the width profile nodes. The clipping is an export option ("Clipped Export" in the export view), that can be disabled.
      The problematic text crashes when moved
      • Li Xiao
      3398
      @VectorStyler I forgot to check the appearance in text editor mode. now I understand. Thanks. I'll send the crash logs file to you.
      Outline Path, Shape Effect - very bad Bug
      3269
      @VectorStyler no problem anymore since the latest build 1.2045
      Offset tool shows a lot of history records
      • monsterfox
      6740
    • Node scaling not working/intermittent
      • debraspicher
      10088
      @VectorStyler Yes, I think that is perfect. Thank you!
      UI Redraw / Refresh Problem - Docked panels missing
      • MWK
      10707
      Hi: @VectorStyler said in UI Redraw / Refresh Problem - Docked panels missing: @MWK This issue should be fixed in build 1.2.038 Thanks for fixing this and the assistance. The new version fixed the problem. Regards, MWK
    • Toolbar Groups unresponsive to clicks; Regularly having trouble opening the group flyout
      • debraspicher
      8028
      The flyout is easier to trigger now, so thanks for this.
    • Ctrl Modifier for Node Tool blocking data entry in Transform Panel
      • debraspicher
      4252
      @VectorStyler Thank you!
    • Style picker tool not working as epected on windows
      • LoginError
      15101
      @LoginError The alternate mode style picker tool issues should be fixed in build 1.2.038
      Mouse Wheel only "add" a Value
      3527
      @Subpath Uploaded a fix. But no version increase, so you must manually remove and reinstall VS.
    • Glitches in Transform tab
      7439
      @VectorStyler "other transforms already applied" -- makes sense, thank you Yet one should expect transformation always applies to the latest effect layer/state in the stack only (retaining the objects current visible appearance). "... the transform pivot selection is disabled". Cool, very helpful. Got it. Though I must confess, that the options in the rightclick-dropdwn confuses me with combinated layer groups and textframes. As occasional user (and user of other vectordrawing programs) one have to click and try quite a lot to get the right setup ie. when rotating shapes.
      Corner Panel, some Presets are broken
      3356
      @VectorStyler This function has been missing for 4 versions (033 - 036).Hope it can be restored as soon as possible.
    • Text on Path gets disconnected when cutting and pasting even when grouped
      2869
      @Boldline Yes, this is a bug. I will try to fix it as soon as possible.
    • Mouse Wheel variable scroll rate
      • debraspicher
      8595
      @debraspicher https://www.vectorstyler.com/forum/topic/3021/alt-scroll-wheel-creates-new-obcjects-while-changing-width-height-value-in-transform-panel/3 https://www.vectorstyler.com/forum/topic/1442/unpredictable-changing-the-value-by-dragging Hi. I understand what you mean. I have mentioned similar problems in the past. And in fact I am still experiencing them, but I have acccpeted them. It's just that each wheel on the mouse has this noticeable click. And this single click works like a single press of the arrow key. In VS, when scrolling through the project window, the mouse always reacts in the same way by moving it by a fixed specified value, but with number fields it is different - every few times the wheel has to make 2 such clicks to change the value. As if the application is doing the calculations and the rest from the calculations accumulate . I would like the wheel click to act like a button click, just like in other apps.
      SVG output error
      • monsterfox
      5350
      @VectorStyler Strange phenomenon, the browser is normal, and Inkscape is normal, but the AI is not normal. However, the paths without color information are lost, which is uniform.
      Crash when trying to save a blend imported from Illustrator EPS
      • Arde
      5635
      This seems to be fixed now in latest release 1.2.036 -- brilliant!
    • [ Text on Path]The offset value does not change to the opposite when the path direction is changed.
      3110
      @encart The way the text offset works is that the original pat is offset by the given amount and then the text is placed one or the other side of that offset.
    • Unresponsive up/down arrows in SVG Export dialog
      • debraspicher
      2583
      @debraspicher I added this to the backlog.
