    • Rearranging tabs and closing first closes first two tabs
      3344
      @Ingolf said in Rearranging tabs and closing first closes first two tabs: Well, it certainly sounds related. It seems to have been related indeed. So far I have not seen the same issue with trying to save when multiple unsaved files are open in tabs since build 101 was released. A very welcome improvement!
    • E
      VS is crashing when I use 'Break Apart' on the text
      3381
      @encart This one crashes here also, I will try to fix this for the next build.
    • _
      Mesh Gradient Toolbar Slider Not Working
      • _NM_
      3161
      @_NM_ Correcting the previous post: Yes, this can be replicated easily with the current build. The fix will be in the next build (already fixed).
      VS 1.1.101 - can't click File tab
      5086
      File "tab"!? No wonder I didn't find it...
      Stroke attributes pop-up menu turns off in the Appearance panel
      1827
      @Harry Yes, this can be replicated on Windows. Will be fixed ASAP.
      Issues with dragging, moving, positioning, etc panels
      • pentool
      2606
      _
      This might be related: The top image is VS's inspectors when VS is the foreground application: However, with another application in the foreground and VS still visible, the middle Layer panel is expanded down, replacing the lower panels: This is reversed when VS is again in the foreground. Maybe it is settings related, but it sure is odd. I have for now refrained from changing any settings other than pertaining to the document size, etc. given the number of unexpected behaviors I am experiencing. Now take a look at the odd resizing behavior in the captured video: https://app.screencast.com/e8kzaPwwyohRY And finally, I somehow ended up like this: and I cannot change it!
    • Color slider bar display problem
      4697
      @861475_VctSt It appears to be software normal. Initially, the display was normal. However, as the work progresses and memory gets tighter, the display becomes erratic, and Finder seems to be affected. I should not use this combination on my 8G old mac. I have reverted back to the Metal, OpenCL combination.
      Stroke sizing is off
      • pentool
      1757
      @pentool Partially replicated, here the stroke drop down keeps the list in "pt". I will try to fix this ASAP.
      Global swatches not syncing with artworking
      • William Kansepa
      3792
      @fde101 Got it! Can be replicated here also. Will be fixed ASAP.
    • _
      Update installer problems ... Invalid resource content!
      • _NM_
      3537
      @_NM_ Yes, this is a new diagnostic message to check for the error that happened in an earlier install. It seems that in some machines the old resource files are kept in the user folder. I will try to find an automatic fix for this in the near future. The settings and workspace can be exported to a file.
      Issues when Resizing Panels
      • William Kansepa
      6618
      In VectorStyler 1.1.101 update, resizing the panels is now easier. Thank you @VectorStyler .
      Regression in Global Swatches
      • William Kansepa
      3637
      @VectorStyler Thanks a lot. Issue is now sorted out in VectorStyler 1.1.101.
      Suddenly the whole UI is blank and won't restore :(
      • maarten
      1782
      @maarten Could be a broken theme file or some settings. Find the user folder of VectorStyler at c:\Users<user name>\AppData\Roaming\NumericPath\VectorStyler1.0\ and remove all
      Issue with Formation Points and Formation Extra Points dialog
      • pentool
      2591
      @pentool Got it, I will try to fix this.
      Pen Tool looses SHIFT+snap when editing a previous anchor
      • pentool
      1836
      @pentool Can be replicated, added to the backlog.
      Appearance Out of Order?
      • fde101
      2623
      @VectorStyler 0_1692444757710_Alphabet.vstyler I have also discovered that it does not export to PDF correctly. I do get the effect if I export to PNG, but if I export to PDF, I only get the yellow fill and the stroke, even if I choose the "Vector Text" option. Rasterizing does not seem to help, but a "Convert To Curves" operation gives me something closer to what I would have expected.
      Gradient doesn't update when deleting a stop
      • pentool
      2545
      @pentool I think the problem is with the fill popup
    • _
      Vector Style 1.1.100 Regression Bug?- Path Panel removed from menu ...
      • _NM_
      8491
      _
      Thank you! I have to say, the mesh gradient's thoughtful implementation is very intuitive. It simply does what you expect it to do.
      Problems with adding/selecting/deleting color swatches from palette
      • pentool
      3589
      @pentool Yes, both panel need to be active. I will try to improve this.
      Palette > Edit Color... (there's nothing to edit)
      • pentool
      3011
      @pentool I added this to the backlog and will try to replicate.
