Intertwine Effect: Where is it?
"Crossing Gap" is the right Effect for something like this
you found it under Shape Effects it Works with a single stroke,
btw with the new mirror feature you may able to create something
this way a little fasterIntertwine works differently
@Subpath Let me try this and get back to you. Thank you!
@Subpath: Nope. Very similar problem. Leading to strange distortions.
Even in your example, you can see what the problem is: The gap does not follow the path.
@Daniel Send me that VS file
in the meantime i found a way to create (fake) gaps with the Intertwine Effect.
Create your Stroke, Expand that Stroke and give it a white outline
now you could use the the Intertwine Effect to fake gaps.
@Subpath: This too failed eventually. Getting the gaps to follow the direction of the path was difficult. I did however manually complete the project.
It's for an AI-based security firm. The central pentagon stands for the SOC, the security operations centre. The circles on the outer perimeter represent the constant social listening of the AI engine. The interlocking lines show unending stream of data. The filled blue hexagons represent co-ordination and continuous monitoring. Sort of like a beehive.
Wanted to share because the client was chuffed and I was very excited. -
@Daniel This might be solvable with some new features in the Intertwine tool.
First I will try to fix the stroke crossing gap problem, but that cannot solve this case with multiple objects
@VectorStyler; Thank you!
By the way, I created a pattern out of the logo. It is very Arabesque. But still, a great looking pattern.
@Daniel
I can't find "Intertwine" anywhere. Is there a search function for menu items, tools or operations?
Here is what I see under Styles:
@ThatMikeGuy "Intertwine" between the "Halftone" and "Drop Shadow" menus (around the middle).
You need to select some objects to activate the menu
The object in your pic seems to be a single stroke ?
For single stroke you have to use the "Crossing Gap"
Shape effect, you find it under Outline shape effectsthe interwine effect needs at least two Objects
the intertwine tool is here, see pic
While our developer is working the intertwine and crossing gap function, I thought through a simple but very effective solution based on @Subpath's suggestion, which might be useful to others who want create intertwine effect perfectly.
First, sketch out your idea:
Mark out alternating sections of above and under for the knotting.
Then create your vector shape.
Then, expand the stroke:
Then apply a stroke to the expanded shape.
Then expand the shape again. Now you'll have two set of expanded strokes.
Now, use the shape builder and cut out the under portions of the knot. You'll be left with the desired result.
@Daniel It turns out that some of these use cases re not suitable for intertwine, but something new.
@VectorStyler: Fair enough. Something like the knotting path effect in Inkscape? https://www.youtube.com/watch?v=08zpOs-yoTw - Check this tutorial.
@Subpath Yes. I used a single path with two stroke parameters on it. The thicker one underneath.
The Crossing Gap gives wierd results for this kind of thing. I'll try duplicating that path and trying Intertwine.
Thanks -
@VectorStyler Doh! I missed that. Maybe since it was grayed out. I guess since it required selection of two paths. I'll try that. Thanks.
How about a search function? Is there a way to search if you don't know where to find a tool or function? -
@Daniel said in Intertwine Effect: Where is it?:
This is actually something I need to create for an upcoming client project.
@Boldline: if you want inspiration for some very intricate knotting patterns, look up Henman Pictogram font 2.
