    Intertwine Effect: Where is it?
    34 Posts 5 Posters 6.9k Views 4 Watching
      Subpath @Daniel
      @Daniel
      ... still a great looking pattern ...
      Indeed, gives Alhambra vibes 🙂
      • T Offline
        ThatMikeGuy @Daniel
        @Daniel
        I can't find "Intertwine" anywhere. Is there a search function for menu items, tools or operations?
        Here is what I see under Styles:
          VectorStyler @ThatMikeGuy
          @ThatMikeGuy "Intertwine" between the "Halftone" and "Drop Shadow" menus (around the middle).
          You need to select some objects to activate the menu
          T 1 Reply Last reply Reply Quote 0
            Subpath @ThatMikeGuy
            @ThatMikeGuy
            The object in your pic seems to be a single stroke ?
            For single stroke you have to use the "Crossing Gap"
            Shape effect, you find it under Outline shape effects
            the interwine effect needs at least two Objects
            the intertwine tool is here, see pic
            • DanielD Offline
              Daniel
              While our developer is working the intertwine and crossing gap function, I thought through a simple but very effective solution based on @Subpath's suggestion, which might be useful to others who want create intertwine effect perfectly.
              First, sketch out your idea:
              Mark out alternating sections of above and under for the knotting.
              Then create your vector shape. 0_1766151144714_3012e868-1cbe-47cc-9a7d-c56db49a7df7-image.png
              Then, expand the stroke:
              Then apply a stroke to the expanded shape.
              Then expand the shape again. Now you'll have two set of expanded strokes.
              Now, use the shape builder and cut out the under portions of the knot. You'll be left with the desired result.
                VectorStyler @Daniel
                @Daniel It turns out that some of these use cases re not suitable for intertwine, but something new.
                • DanielD Offline
                  Daniel @VectorStyler
                  @VectorStyler: Fair enough. Something like the knotting path effect in Inkscape? https://www.youtube.com/watch?v=08zpOs-yoTw - Check this tutorial. 🙂
                  • T Offline
                    ThatMikeGuy @Subpath
                    @Subpath Yes. I used a single path with two stroke parameters on it. The thicker one underneath.
                    The Crossing Gap gives wierd results for this kind of thing. I'll try duplicating that path and trying Intertwine.
                    Thanks
                    • T Offline
                      ThatMikeGuy @VectorStyler
                      @VectorStyler Doh! I missed that. Maybe since it was grayed out. I guess since it required selection of two paths. I'll try that. Thanks.
                      How about a search function? Is there a way to search if you don't know where to find a tool or function?
                        Boldline @Daniel
                        @Daniel said in Intertwine Effect: Where is it?:
                        This is actually something I need to create for an upcoming client project.
                        • DanielD Offline
                          Daniel @Boldline
                          @Boldline: if you want inspiration for some very intricate knotting patterns, look up Henman Pictogram font 2.
                          S BoldlineB 2 Replies Last reply Reply Quote 3
                            @ThatMikeGuy
                            I just wanted to let you know that @VectorStyler is already working on the problems with the "crossing gap" shape effect.
                            It is already mentioned in the top region of this thread.
                              Subpath @Daniel
                              @Daniel
                              WOW !!!
                              Thats a lot Variations.
                                Some more Knots 🙂
                                as inspiration for the intertwine feature
                                Knotplot is a program for creating knots in celtic style and many more
                                here the Link
                                https://knotplot.com/
                                  Subpath @Daniel
                                  @Daniel
                                  Using the ShapeBuilder is also a great Idea !
                                  • DanielD Offline
                                    Daniel @Subpath
                                    @Subpath: Knot plot is great! Thanks for sharing. Yes, Henman is one of my favourite ornamental family. It's a family of three. Patterns, borders and individual ornaments. By a legendary Armenian designer.
                                      Boldline @Daniel
                                      @Daniel great thank you for the suggestion. I’ll check it out
                                      • DanielD Offline
                                        Daniel
                                        If anyone would like to take a stab. I am taking on a challenge to reconstruct and reverse engineer every single ornament of the three Henman family. I'll post instructions as I go along. So you can try. 🙂
                                          Subpath @Daniel
                                          @Daniel
                                          looks great! 👍
                                          Btw. would it be possible to create a thread about this in the tutorial section?
                                          That way it would be easier for other users to find.
