    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
      created a, color-wise, somewhat structured version.
        A fairly simple pattern, what made it special was
        the use of β€œcolorize” with my own palette.
        Menu > Effects > Replace colors > Colorize...
          another one of my pattern experiments
          also colored via colorize like the one above
            Working on a Mosaic Project, reusing an old pattern i made,
            here a Result. Everything made in VectorStyler. To get slightly
            different colors for each mosaic tile "Disturb Colors" was used.
            Menu > Effects > Replace Colors > Disturb Colors
              played with randomness
              Was playing with randomize in the Repeater using just a quad.
              Did a Boolean "Dividide" with the Result, then a "Offset Path" Shape Effect
              " Inner Offset" and at least i use "Colorize" with a Color Palette i made.
                Someone said the previous picture looked like a collection
                of Polaroid photos, so I made a version like that too.
                This was made with the help of Actions (Vectorstyler Macros)
                to get the Polaroid look.
                  Continued a bit with my mosaic project.
                  I had the idea of ​​a kind of natural looking color gradient for mosaics.
                  The "Color Disturb" function was no help because of the gradient required.
                  Instead, I created a duplicate version, colored it using "Colorize"
                  using my palette and made it transparent (20%). I placed it over
                  the gradient, which creates nice, slightly differently colored tiles.
                    Ingolf @Subpath
                    @Subpath said in Just a Pattern:
                    Another pattern, created in Vectorstyler
                    is an overlay of different patterns and
                    experiments with combined stroke stripes
                    This one looks truly elegant and aesthetically pleasing.
                      Subpath @Ingolf
                      @Ingolf
                      thank you, i like that too.
                        Been playing around with some lines/paths
                        and decided to try a mosaic with them.
                        Made two paths and a blend between them
                        the deformation was made in CorelDraw because
                        they look better, but VectorStyler wants to improve
                        the deformation tools
                        The rest are made in VectorStyler.
                        These are three times the same paths/shapes (layered)
                        one for the fill, one for the mosaic and one for the transparent
                        and randomly colored mosaic to give it a little more life
                          While browsing through old things I've made, I found this
                          variation of the blue floral pattern I posted above.
                          • H Offline
                            Harry @Subpath
                            Interesting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap πŸ™‚ - example
                              Subpath @Harry
                              @Harry
                              Thanks, you're actually on the right track πŸ™‚
                              The pattern you mentioned is one of several experiments that
                              should ultimately led to something like a cobblestone/mosaic.
                              My goal was to figure out a way how to create something like
                              that in Vectorstyler. I'm still experimenting a bit, but when
                              everything will fall together, I'll post a tutorial.
                                @Li-Xiao created a few designs in this thread
                                https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effect
                                I couldn't resist taking one and trying out Colorize.
                                Here the needed Steps
                                Select the Design
                                Expand Appearence
                                Ungroup the Design
                                Do a Boolean Divide
                                Fill the Result, color doesnt matter
                                (colorize work on filled objects only)
                                Call Colorize
                                Call Colorize Options
                                deselect "Change Strokes"
                                Choose a Palette/or some Colors
                                ( you can create your own Palette
                                or select some colors using the
                                system palette )
                                You could also color only the Strokes if you like.
                                Here another one
                                • L Offline
                                  Li Xiao @Subpath
                                  @Subpath Very beautiful πŸ‘ , I also really enjoy using Colorize.
                                    Metaball try made in VectorStyler
                                    Devil DinosaurD 1 Reply Last reply Reply Quote 5
                                    • Devil DinosaurD Offline
                                      Devil Dinosaur @Subpath
                                      @Subpath Cool ! πŸ‘
                                      Fred.
                                        Subpath @Devil Dinosaur
                                        @Devil-Dinosaur, thank you
                                        Indeed.
                                        Will do a little Tutorial and show a few Tricks.
                                          Some optical illusion, i made a while ago.
                                          The base was simple a yellow stroke where i place a pattern Brush
                                          in the same size above and the copy scale and rotate it.
                                          Here the Base
                                          Here the Pattern
                                            Another interesting optical illusion.
                                            Made in VectorStyler and Black Ink
                                            Dashed Lines, random colorized, the whole thing copied, and
                                            two copies placed underneath, each with a Gaussian blur image effect
                                            Black Ink
                                            Only for Symmetry, because of its symmetry Fusion Feature.
