    Just a Pattern
    43 Posts 7 Posters 60.9k Views 7 Watching
      Another nice find, made entirely in Vectorstyler
      with a little help from corner tool and the
      colorize feature 🙂
        While i was I looking at this pattern, I had the idea that
        it might look like a peacock's tail, so I create this one.
          well, I think you can also see it as a kind of pattern
          saw this interesting design made with CorelDraw
          and i recreated it in VectorStyler
          (Shapebuilder was involved)
            made a variation, also all in VectorStyler
              some further variations of this design
              seems that i am not short on Ideas 🙂
              will do a tutorial which tricks VectorStyler offers
              to get such results
              the first tutorial is online, you found it here:
              https://www.vectorstyler.com/forum/topic/4624/using-the-extend-path-tool-to-adjust-a-blend
              this second tutorial shows how to replace dashes of a stroke with another shape
              https://www.vectorstyler.com/forum/topic/4625/replace-dashed-line-strokes-with-another-shape
                Another pattern, created in Vectorstyler
                is an overlay of different patterns and
                experiments with combined stroke stripes
                IngolfI 1 Reply Last reply Reply Quote 6
                  I'm still experimenting with the possibilities Stroke Stripe offers
                  for creating patterns.
                  It started with that simple pattern below, I added an offset shape effect
                  and used Stroke Stripe with Boolean Combine on it.
                  The Colors were made with Colorize.
                  To get such patterns from Stroke Stripe it should be closed shapes
                  and then do a Boolean Combine with it.
                    Found some new ways for creating Pattern in VS.
                    You could also take look at this link
                    https://www.vectorstyler.com/forum/topic/4843/inverted-wave-zig-zag-with-the-outline-zigzag-shape-effect
                    Here just one Result, but many many Variations
                    are possible this way
                      created a, color-wise, somewhat structured version.
                        A fairly simple pattern, what made it special was
                        the use of “colorize” with my own palette.
                        Menu > Effects > Replace colors > Colorize...
                          another one of my pattern experiments
                          also colored via colorize like the one above
                            Working on a Mosaic Project, reusing an old pattern i made,
                            here a Result. Everything made in VectorStyler. To get slightly
                            different colors for each mosaic tile "Disturb Colors" was used.
                            Menu > Effects > Replace Colors > Disturb Colors
                              played with randomness
                              Was playing with randomize in the Repeater using just a quad.
                              Did a Boolean "Dividide" with the Result, then a "Offset Path" Shape Effect
                              " Inner Offset" and at least i use "Colorize" with a Color Palette i made.
                                Someone said the previous picture looked like a collection
                                of Polaroid photos, so I made a version like that too.
                                This was made with the help of Actions (Vectorstyler Macros)
                                to get the Polaroid look.
                                  Continued a bit with my mosaic project.
                                  I had the idea of ​​a kind of natural looking color gradient for mosaics.
                                  The "Color Disturb" function was no help because of the gradient required.
                                  Instead, I created a duplicate version, colored it using "Colorize"
                                  using my palette and made it transparent (20%). I placed it over
                                  the gradient, which creates nice, slightly differently colored tiles.
                                    Ingolf @Subpath
                                    @Subpath said in Just a Pattern:
                                    This one looks truly elegant and aesthetically pleasing.
                                      Subpath @Ingolf
                                      @Ingolf
                                      thank you, i like that too.
                                        Been playing around with some lines/paths
                                        and decided to try a mosaic with them.
                                        Made two paths and a blend between them
                                        the deformation was made in CorelDraw because
                                        they look better, but VectorStyler wants to improve
                                        the deformation tools
                                        The rest are made in VectorStyler.
                                        These are three times the same paths/shapes (layered)
                                        one for the fill, one for the mosaic and one for the transparent
                                        and randomly colored mosaic to give it a little more life
                                          While browsing through old things I've made, I found this
                                          variation of the blue floral pattern I posted above.
                                          • H Offline
                                            Harry @Subpath
                                            Interesting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap 🙂 - example
