    Just a Pattern
    43 Posts 7 Posters 60.9k Views 7 Watching
      Subpath @Ingolf
      @Ingolf
      thank you, i like that too.
        Been playing around with some lines/paths
        and decided to try a mosaic with them.
        Made two paths and a blend between them
        the deformation was made in CorelDraw because
        they look better, but VectorStyler wants to improve
        the deformation tools
        The rest are made in VectorStyler.
        These are three times the same paths/shapes (layered)
        one for the fill, one for the mosaic and one for the transparent
        and randomly colored mosaic to give it a little more life
          While browsing through old things I've made, I found this
          variation of the blue floral pattern I posted above.
          • H Offline
            Harry @Subpath
            @Subpath said in Just a Pattern:
            Interesting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap 🙂 - example
              Subpath @Harry
              @Harry
              Thanks, you're actually on the right track 🙂
              The pattern you mentioned is one of several experiments that
              should ultimately led to something like a cobblestone/mosaic.
              My goal was to figure out a way how to create something like
              that in Vectorstyler. I'm still experimenting a bit, but when
              everything will fall together, I'll post a tutorial.
                @Li-Xiao created a few designs in this thread
                https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effect
                I couldn't resist taking one and trying out Colorize.
                Here the needed Steps
                Select the Design
                Expand Appearence
                Ungroup the Design
                Do a Boolean Divide
                Fill the Result, color doesnt matter
                (colorize work on filled objects only)
                Call Colorize
                Call Colorize Options
                deselect "Change Strokes"
                Choose a Palette/or some Colors
                ( you can create your own Palette
                or select some colors using the
                system palette )
                You could also color only the Strokes if you like.
                Here another one
                • L Online
                  Li Xiao @Subpath
                  @Subpath Very beautiful 👍 , I also really enjoy using Colorize.
                    Metaball try made in VectorStyler
                    Devil DinosaurD 1 Reply Last reply Reply Quote 5
                    • Devil DinosaurD Offline
                      Devil Dinosaur @Subpath
                      @Subpath Cool ! 👍
                      Fred.
                        Subpath @Devil Dinosaur
                        @Devil-Dinosaur, thank you
                        Indeed.
                        Will do a little Tutorial and show a few Tricks.
                          Some optical illusion, i made a while ago.
                          The base was simple a yellow stroke where i place a pattern Brush
                          in the same size above and the copy scale and rotate it.
                          Here the Base
                          Here the Pattern
                            Another interesting optical illusion.
                            Made in VectorStyler and Black Ink
                            Dashed Lines, random colorized, the whole thing copied, and
                            two copies placed underneath, each with a Gaussian blur image effect
                            Black Ink
                            Only for Symmetry, because of its symmetry Fusion Feature.
                              Played a bit with a multiccolor gradient in strokes.
                              You could look at this little tutorial of mine
                              https://www.vectorstyler.com/forum/topic/5694/way-to-create-a-multi-color-gradient-from-colors-of-a-color-palette
                              • E Offline
                                EricP @Subpath
                                @Subpath cool effect !
                                  Subpath @EricP
                                  @EricP
                                  Thank you.
                                  Yes it looks nice and its realtive easy to do.
                                  I just had to relocate some stroke gradients
                                  Yes, it looks nice and is relatively easy to create.
                                  I just had to reposition some of the gradients a bit.
                                  I did this with separate strokes that weren't combined or grouped.
                                  If you select all the strokes and then apply a gradient (see the method in the link)
                                  over them, the gradients will be in slightly different positions.
                                  Ultimately, I actually liked the slightly more chaotic result here even better.
                                  Btw i used a concentric gradient
                                    marce @Subpath
                                    @Subpath Great thread and posts. Thanks. Forum says "you can upvote a user only six times per day", so sorry guys i didnt give the like i wanted meanwhile reading.
                                    Memory 48gb ddr4
                                    NVMe CT100p 1TB
                                      Subpath @marce
                                      @marce said in Just a Pattern:
                                      @Subpath "Forum says "you can upvote a user only six times per day",
                                      Very curious, didn't know that.
                                      But dont worry, if my post inspire people or
                                      are helpful then this is fine enough 🙂
                                        Created using:
                                        The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
                                        (See Manual how)
                                        The Style Picker Feature, which allows you to transfer style attributes
                                        from one group of objects to another.
                                        You could take look at this Link
                                        https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
