    Just a Pattern
    43 Posts 7 Posters 60.9k Views 7 Watching
      Found some new ways for creating Pattern in VS.
      You could also take look at this link
      https://www.vectorstyler.com/forum/topic/4843/inverted-wave-zig-zag-with-the-outline-zigzag-shape-effect
      Here just one Result, but many many Variations
      are possible this way
        created a, color-wise, somewhat structured version.
          A fairly simple pattern, what made it special was
          the use of β€œcolorize” with my own palette.
          Menu > Effects > Replace colors > Colorize...
            another one of my pattern experiments
            also colored via colorize like the one above
              Working on a Mosaic Project, reusing an old pattern i made,
              here a Result. Everything made in VectorStyler. To get slightly
              different colors for each mosaic tile "Disturb Colors" was used.
              Menu > Effects > Replace Colors > Disturb Colors
                played with randomness
                Was playing with randomize in the Repeater using just a quad.
                Did a Boolean "Dividide" with the Result, then a "Offset Path" Shape Effect
                " Inner Offset" and at least i use "Colorize" with a Color Palette i made.
                  Someone said the previous picture looked like a collection
                  of Polaroid photos, so I made a version like that too.
                  This was made with the help of Actions (Vectorstyler Macros)
                  to get the Polaroid look.
                    Continued a bit with my mosaic project.
                    I had the idea of ​​a kind of natural looking color gradient for mosaics.
                    The "Color Disturb" function was no help because of the gradient required.
                    Instead, I created a duplicate version, colored it using "Colorize"
                    using my palette and made it transparent (20%). I placed it over
                    the gradient, which creates nice, slightly differently colored tiles.
                      Ingolf @Subpath
                      @Subpath said in Just a Pattern:
                      Another pattern, created in Vectorstyler
                      is an overlay of different patterns and
                      experiments with combined stroke stripes
                      This one looks truly elegant and aesthetically pleasing.
                        Subpath @Ingolf
                        @Ingolf
                        thank you, i like that too.
                          Been playing around with some lines/paths
                          and decided to try a mosaic with them.
                          Made two paths and a blend between them
                          the deformation was made in CorelDraw because
                          they look better, but VectorStyler wants to improve
                          the deformation tools
                          The rest are made in VectorStyler.
                          These are three times the same paths/shapes (layered)
                          one for the fill, one for the mosaic and one for the transparent
                          and randomly colored mosaic to give it a little more life
                            While browsing through old things I've made, I found this
                            variation of the blue floral pattern I posted above.
                            • H Offline
                              Harry @Subpath
                              Interesting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap πŸ™‚ - example
                                Subpath @Harry
                                @Harry
                                Thanks, you're actually on the right track πŸ™‚
                                The pattern you mentioned is one of several experiments that
                                should ultimately led to something like a cobblestone/mosaic.
                                My goal was to figure out a way how to create something like
                                that in Vectorstyler. I'm still experimenting a bit, but when
                                everything will fall together, I'll post a tutorial.
                                  @Li-Xiao created a few designs in this thread
                                  https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effect
                                  I couldn't resist taking one and trying out Colorize.
                                  Here the needed Steps
                                  Select the Design
                                  Expand Appearence
                                  Ungroup the Design
                                  Do a Boolean Divide
                                  Fill the Result, color doesnt matter
                                  (colorize work on filled objects only)
                                  Call Colorize
                                  Call Colorize Options
                                  deselect "Change Strokes"
                                  Choose a Palette/or some Colors
                                  ( you can create your own Palette
                                  or select some colors using the
                                  system palette )
                                  You could also color only the Strokes if you like.
                                  Here another one
                                  • L Offline
                                    Li Xiao @Subpath
                                    @Subpath Very beautiful πŸ‘ , I also really enjoy using Colorize.
                                      Metaball try made in VectorStyler
                                      Devil DinosaurD 1 Reply Last reply Reply Quote 5
                                      • Devil DinosaurD Offline
                                        Devil Dinosaur @Subpath
                                        @Subpath Cool ! πŸ‘
                                        Fred.
                                          Subpath @Devil Dinosaur
                                          @Devil-Dinosaur, thank you
                                          Indeed.
                                          Will do a little Tutorial and show a few Tricks.
                                            Some optical illusion, i made a while ago.
                                            The base was simple a yellow stroke where i place a pattern Brush
                                            in the same size above and the copy scale and rotate it.
                                            Here the Base
                                            Here the Pattern
