    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
      Ingolf @Subpath
      @Subpath said in Just a Pattern:
      Another pattern, created in Vectorstyler
      is an overlay of different patterns and
      experiments with combined stroke stripes
      This one looks truly elegant and aesthetically pleasing.
        Subpath @Ingolf
        @Ingolf
        thank you, i like that too.
          Been playing around with some lines/paths
          and decided to try a mosaic with them.
          Made two paths and a blend between them
          the deformation was made in CorelDraw because
          they look better, but VectorStyler wants to improve
          the deformation tools
          The rest are made in VectorStyler.
          These are three times the same paths/shapes (layered)
          one for the fill, one for the mosaic and one for the transparent
          and randomly colored mosaic to give it a little more life
            While browsing through old things I've made, I found this
            variation of the blue floral pattern I posted above.
            • H Offline
              Harry @Subpath
              Interesting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap πŸ™‚ - example
                Subpath @Harry
                @Harry
                Thanks, you're actually on the right track πŸ™‚
                The pattern you mentioned is one of several experiments that
                should ultimately led to something like a cobblestone/mosaic.
                My goal was to figure out a way how to create something like
                that in Vectorstyler. I'm still experimenting a bit, but when
                everything will fall together, I'll post a tutorial.
                  @Li-Xiao created a few designs in this thread
                  https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effect
                  I couldn't resist taking one and trying out Colorize.
                  Here the needed Steps
                  Select the Design
                  Expand Appearence
                  Ungroup the Design
                  Do a Boolean Divide
                  Fill the Result, color doesnt matter
                  (colorize work on filled objects only)
                  Call Colorize
                  Call Colorize Options
                  deselect "Change Strokes"
                  Choose a Palette/or some Colors
                  ( you can create your own Palette
                  or select some colors using the
                  system palette )
                  You could also color only the Strokes if you like.
                  Here another one
                  • L Offline
                    Li Xiao @Subpath
                    @Subpath Very beautiful πŸ‘ , I also really enjoy using Colorize.
                      Metaball try made in VectorStyler
                      Devil DinosaurD 1 Reply Last reply Reply Quote 5
                      • Devil DinosaurD Offline
                        Devil Dinosaur @Subpath
                        @Subpath Cool ! πŸ‘
                        Fred.
                          Subpath @Devil Dinosaur
                          @Devil-Dinosaur, thank you
                          Indeed.
                          Will do a little Tutorial and show a few Tricks.
                            Some optical illusion, i made a while ago.
                            The base was simple a yellow stroke where i place a pattern Brush
                            in the same size above and the copy scale and rotate it.
                            Here the Base
                            Here the Pattern
                              Another interesting optical illusion.
                              Made in VectorStyler and Black Ink
                              Dashed Lines, random colorized, the whole thing copied, and
                              two copies placed underneath, each with a Gaussian blur image effect
                              Black Ink
                              Only for Symmetry, because of its symmetry Fusion Feature.
                                Played a bit with a multiccolor gradient in strokes.
                                You could look at this little tutorial of mine
                                https://www.vectorstyler.com/forum/topic/5694/way-to-create-a-multi-color-gradient-from-colors-of-a-color-palette
                                • E Offline
                                  EricP @Subpath
                                  @Subpath cool effect !
                                    Subpath @EricP
                                    @EricP
                                    Thank you.
                                    Yes it looks nice and its realtive easy to do.
                                    I just had to relocate some stroke gradients
                                    Yes, it looks nice and is relatively easy to create.
                                    I just had to reposition some of the gradients a bit.
                                    I did this with separate strokes that weren't combined or grouped.
                                    If you select all the strokes and then apply a gradient (see the method in the link)
                                    over them, the gradients will be in slightly different positions.
                                    Ultimately, I actually liked the slightly more chaotic result here even better.
                                    Btw i used a concentric gradient
                                      marce @Subpath
                                      @Subpath Great thread and posts. Thanks. Forum says "you can upvote a user only six times per day", so sorry guys i didnt give the like i wanted meanwhile reading.
                                      Memory 48gb ddr4
                                      NVMe CT100p 1TB
                                        Subpath @marce
                                        @marce said in Just a Pattern:
                                        @Subpath "Forum says "you can upvote a user only six times per day",
                                        Very curious, didn't know that.
                                        But dont worry, if my post inspire people or
                                        are helpful then this is fine enough πŸ™‚
                                          Created using:
                                          The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
                                          (See Manual how)
                                          The Style Picker Feature, which allows you to transfer style attributes
                                          from one group of objects to another.
                                          You could take look at this Link
                                          https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
                                            I used a shape with a multi-colored gradient to colorize a bunch of strokes using the Repeater,
                                            and transferred the color (style)β€”using the new Style Picker Tool Featureβ€” to a bunch of
                                            other Strokes created with the Blend function.
                                            The strokes colored with the Repeater
                                            Here the Result
                                            1 Reply Last reply Reply Quote 8
