    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
      Another pattern, created in Vectorstyler
      is an overlay of different patterns and
      experiments with combined stroke stripes
      IngolfI 1 Reply Last reply Reply Quote 6
        I'm still experimenting with the possibilities Stroke Stripe offers
        for creating patterns.
        It started with that simple pattern below, I added an offset shape effect
        and used Stroke Stripe with Boolean Combine on it.
        The Colors were made with Colorize.
        To get such patterns from Stroke Stripe it should be closed shapes
        and then do a Boolean Combine with it.
          Found some new ways for creating Pattern in VS.
          You could also take look at this link
          https://www.vectorstyler.com/forum/topic/4843/inverted-wave-zig-zag-with-the-outline-zigzag-shape-effect
          Here just one Result, but many many Variations
          are possible this way
            created a, color-wise, somewhat structured version.
              A fairly simple pattern, what made it special was
              the use of “colorize” with my own palette.
              Menu > Effects > Replace colors > Colorize...
                another one of my pattern experiments
                also colored via colorize like the one above
                  Working on a Mosaic Project, reusing an old pattern i made,
                  here a Result. Everything made in VectorStyler. To get slightly
                  different colors for each mosaic tile "Disturb Colors" was used.
                  Menu > Effects > Replace Colors > Disturb Colors
                    played with randomness
                    Was playing with randomize in the Repeater using just a quad.
                    Did a Boolean "Dividide" with the Result, then a "Offset Path" Shape Effect
                    " Inner Offset" and at least i use "Colorize" with a Color Palette i made.
                      Someone said the previous picture looked like a collection
                      of Polaroid photos, so I made a version like that too.
                      This was made with the help of Actions (Vectorstyler Macros)
                      to get the Polaroid look.
                        Continued a bit with my mosaic project.
                        I had the idea of ​​a kind of natural looking color gradient for mosaics.
                        The "Color Disturb" function was no help because of the gradient required.
                        Instead, I created a duplicate version, colored it using "Colorize"
                        using my palette and made it transparent (20%). I placed it over
                        the gradient, which creates nice, slightly differently colored tiles.
                          Ingolf @Subpath
                          @Subpath said in Just a Pattern:
                          This one looks truly elegant and aesthetically pleasing.
                            Subpath @Ingolf
                            @Ingolf
                            thank you, i like that too.
                              Been playing around with some lines/paths
                              and decided to try a mosaic with them.
                              Made two paths and a blend between them
                              the deformation was made in CorelDraw because
                              they look better, but VectorStyler wants to improve
                              the deformation tools
                              The rest are made in VectorStyler.
                              These are three times the same paths/shapes (layered)
                              one for the fill, one for the mosaic and one for the transparent
                              and randomly colored mosaic to give it a little more life
                                While browsing through old things I've made, I found this
                                variation of the blue floral pattern I posted above.
                                • H Offline
                                  Harry @Subpath
                                  Interesting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap 🙂 - example
                                    Subpath @Harry
                                    @Harry
                                    Thanks, you're actually on the right track 🙂
                                    The pattern you mentioned is one of several experiments that
                                    should ultimately led to something like a cobblestone/mosaic.
                                    My goal was to figure out a way how to create something like
                                    that in Vectorstyler. I'm still experimenting a bit, but when
                                    everything will fall together, I'll post a tutorial.
                                      @Li-Xiao created a few designs in this thread
                                      https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effect
                                      I couldn't resist taking one and trying out Colorize.
                                      Here the needed Steps
                                      Select the Design
                                      Expand Appearence
                                      Ungroup the Design
                                      Do a Boolean Divide
                                      Fill the Result, color doesnt matter
                                      (colorize work on filled objects only)
                                      Call Colorize
                                      Call Colorize Options
                                      deselect "Change Strokes"
                                      Choose a Palette/or some Colors
                                      ( you can create your own Palette
                                      or select some colors using the
                                      system palette )
                                      You could also color only the Strokes if you like.
                                      Here another one
                                      • L Offline
                                        Li Xiao @Subpath
                                        @Subpath Very beautiful 👍 , I also really enjoy using Colorize.
                                          Metaball try made in VectorStyler
                                          Devil DinosaurD 1 Reply Last reply Reply Quote 5
                                          • Devil DinosaurD Offline
                                            Devil Dinosaur @Subpath
                                            @Subpath Cool ! 👍
                                            Fred.
