    VectorStyler Manual | PDF
    70 Posts 10 Posters 240.8k Views 9 Watching
    • R Offline
      richbyte @freggern
      @freggern Thank You for making this! 👋
        freggern
        Small update of the manual (https://k00.fr/xucgr0j9)
        • Alternative rendering for EULA pages to reduce space (page 50)
        Included changes of the html pages (thx @vectoradmin)
        • New chapters for Repeater (page 1305)
        • Additions! Shortcuts (Win, Mac), Change Colors -> Intensity, Preferences -> Document Editor settings, Layer -> Layer Panel Options, Toolbox -> Symbol Tools, Editpath -> The Trim and Join Tool
        • profileicon.png fixed
          Boldline @freggern
          @freggern Thanks for doing this and for keeping it updated as we go along.
          If I see an error or misspelling in the documentation, should I be alerting both you and @vectoradmin ?
            freggern
            It depends on where the error or misspelling can be found. I only need to know when it happens only in the pdf file. I can do nothing when the misspelling is on the documentation website. I generate the pdf file in 3 steps that I trigger: Crawl the website, generate a latex file with python out of the website files and then generate the pdf file from the latex file. I don't plan to manually fix misspelling or errors that can be found in the website files. I can only fix "errors" that happend in the process of generating the pdf file.
            Like for example on my todo list:
            • & like Canvas & Artboard doesn't show as Canvas & Artboard
            • Color Palette Bar has some not correct rendered images
            • SVG EFFECTS - Diffuse Light has some not correct rendered images
            • Better floating positioning for images
            • Support for intern links in the pdf
              @Boldline Let me know if there are spelling errors in the documentation.
              You can also post it here.
                @vectoradmin no problem - minor one in the "shape paint" section.
                "Original"
                0_1641278430754_868c69bd-94be-4453-a707-09ce9fcad8ea-BLD 2022-01-04 at 01.38.20.png
                  freggern
                  @vectoradmin There is a wrong link on the page https://www.vectorstyler.com/documentation/repeater/ unter the overview headline
                  • "Not Found" (404) at link https://www.vectorstyler.com/documentation/repeater/geometry/ (from https://www.vectorstyler.com/documentation/repeater/) => correct link is/repeater/geometries/
                    VectorStyler @freggern
                    @freggern Should be fixed now!
                      freggern
                      New update of the manual (https://k00.fr/xucgr0j9)
                      • Support for internal links (When you click on a link to another chapter, it jumps to the correct chapter of the PDF)
                      • & display now correct as &
                      • Fix rendering of images as part of an HTML p element
                      Included changes of the HTML pages (thx @vectoradmin)
                      • Added! What is new in VectorStyler 1.1
                      • Correct an internal link
                      BoldlineB S 3 Replies Last reply Reply Quote 6
                        Boldline @freggern
                        @freggern Love that you've taken on the task to do this - thanks! It keeps getting better all the time
                          Subpath @freggern
                          @freggern
                          i am also really gratefully for your work 👍 👍 👍
                            Boldline @freggern
                            @vectorstyler @freggern should we move the PDF file of the documentation over to a pinned thread in the general discussion? This way it's easy to find each time @freggern updates it? Right now it's within an random question and would be harder to go back and find later on.
                              @Boldline A pinned thread in "Tutorials" or "General Discussion" will do.
                                freggern
                                @Boldline @vectoradmin I change the first post and rename the thread title. @vectoradmin Feel free to pin the thread.
                                  freggern
                                  Is it intentional that the category tutorial is private. So only logined user can see the category or access threads in it?
                                    @freggern Should be fixed now.
                                      👍 to both Ideas.
                                      I was also not so happy that the Tutorials could
                                      only be read by registered forum users.
                                      Found interested People unnecessarily excluded.
                                        freggern
                                        • tables now support to hide the first column of the modifier-tables (is hidden on the website per CSS-rule)
                                        • column and row now separated by lines
                                        • there was a bug where it was possible that fields get combined.
                                        • redesign the info box
                                        • disable all separator lines
                                        • fix a bug where \ in the text doesn't display correct
                                        • add 1 cm to the textlinewidth
                                        • Updated some images like color palette and layer panel
                                        • Add shortcuts
                                        1 Reply Last reply Reply Quote 7
                                          freggern
                                          New update, only include changes of the HTML pages (thx @vectoradmin) - (https://k00.fr/xucgr0j9).
                                          • Add shortcuts
                                            freggern
                                            New update with all the changes @vectoradmin did to the documentation.
                                            • Added: Shape Effects -> Outline -> Node Bump
                                            • Added: Path Panal -> Describe fourth row
                                            • Updated: Images for like Preferences
                                            • Update Shortcuts (was already in an unannounced release of the PDF manual)
                                            • Typos
