    VectorStyler Manual | PDF
    70 Posts 10 Posters 240.8k Views 9 Watching
      Boldline @freggern
      @freggern Love that you've taken on the task to do this - thanks! It keeps getting better all the time
        Subpath @freggern
        @freggern
        i am also really gratefully for your work 👍 👍 👍
          Boldline @freggern
          @vectorstyler @freggern should we move the PDF file of the documentation over to a pinned thread in the general discussion? This way it's easy to find each time @freggern updates it? Right now it's within an random question and would be harder to go back and find later on.
            @Boldline A pinned thread in "Tutorials" or "General Discussion" will do.
              freggern
              @Boldline @vectoradmin I change the first post and rename the thread title. @vectoradmin Feel free to pin the thread.
                freggern
                Is it intentional that the category tutorial is private. So only logined user can see the category or access threads in it?
                  VectorStyler @freggern
                  @freggern Should be fixed now.
                    👍 to both Ideas.
                    I was also not so happy that the Tutorials could
                    only be read by registered forum users.
                    Found interested People unnecessarily excluded.
                      freggern
                      New update of the manual (https://k00.fr/xucgr0j9)
                      • tables now support to hide the first column of the modifier-tables (is hidden on the website per CSS-rule)
                      • column and row now separated by lines
                      • there was a bug where it was possible that fields get combined.
                      • redesign the info box
                      • disable all separator lines
                      • fix a bug where \ in the text doesn't display correct
                      • add 1 cm to the textlinewidth
                      Included changes of the HTML pages (thx @vectoradmin)
                      • Updated some images like color palette and layer panel
                      • Add shortcuts
                      1 Reply Last reply Reply Quote 7
                        freggern
                        New update, only include changes of the HTML pages (thx @vectoradmin) - (https://k00.fr/xucgr0j9).
                        • Add shortcuts
                          freggern
                          New update with all the changes @vectoradmin did to the documentation.
                          • Added: Shape Effects -> Outline -> Node Bump
                          • Added: Path Panal -> Describe fourth row
                          • Updated: Images for like Preferences
                          • Update Shortcuts (was already in an unannounced release of the PDF manual)
                          • Typos
                            @freggern You're doing an awesome job keeping the pdf manual updated and available. thank you for all your hard work.
                            A spacing issue I wanted to bring to your attention - not sure if there's an easy fix.
                            i noticed a few cases in the table of contents, especially as the number switch from two digits to three -the space gets tight and the letters join together.
                            further down there's some similar spacing issues as the secondary numbers hit three digits
                            0_1647966738302_ba205407-dc4e-47ed-a502-95e712e6d0b5-BLD 2022-03-22 at 12.30.05.png
                              freggern
                              @Boldline I updated the PDF with a different spacing configuration for the TOC, so the overlap should not happen anymore.
                                Boldline @freggern
                                @freggern That looks so much better - thanks for getting that fixed up.
                                  freggern @Boldline
                                  @Boldline 👍 If you notice something else or have another idear to improve, let me know.
                                    freggern
                                    New bigger Update:
                                    Content
                                    • Thanks to @Victor-Vector I added the Boolean Operations Reference Guide Images to the PDF-Manual. More information here: https://www.vectorstyler.com/forum/topic/1758/boolean-operations-reference-guide
                                    A lot of redesigns
                                    In this update, I focus on the design that I duck out because of needed code changes of the import script.
                                    • Redesign the chapter title at the beginning of a chapter
                                    • Redesign completely the tables to a modern design and support for table headers (when exists)
                                    • Redesign the information boxes that it match to the table and chapter design
                                    • Update the title page with a date and sources, and adjust the size of the title.
                                    • Update the page header
                                    Bugs
                                    • Fix a bug in the table
                                    Victor VectorV 1 Reply Last reply Reply Quote 3
                                    • Victor VectorV Offline
                                      Victor Vector @freggern
                                      @freggern I like the redesign changes you made. Thanks for the new version!
                                        freggern
                                        New Update
                                        • Thanks to @Victor-Vector I added the Blend Modes Reference Guide Images to the chapter Transparency of the PDF-Manual. More information here: https://www.vectorstyler.com/forum/topic/1827/blend-modes-reference-guide
                                        • Includes same small fixes that @vectoradmin did to the documentation like: master -> clone source
                                        S 1 Reply Last reply Reply Quote 6
                                          Subpath @freggern
                                          @freggern
                                          Cant thank you enough for creating a PDF-Helpfile.
                                          Very helpful. Great work as always.
                                          Special thanks to @Victor-Vector
                                            freggern
                                            New Update
                                            • Thanks to @Victor-Vector I added the Shape Effects Inventory - a Reference Guide to the PDF-Manual. More information here: https://www.vectorstyler.com/forum/topic/2011/shape-effects-inventory-a-reference-guide
                                            • Rename vectoradmin to VectorStyler on the title page source material list
