    VectorStyler Manual | PDF
    70 Posts 10 Posters 240.8k Views 9 Watching
      freggern
      @vectoradmin There is a wrong link on the page https://www.vectorstyler.com/documentation/repeater/ unter the overview headline
      • "Not Found" (404) at link https://www.vectorstyler.com/documentation/repeater/geometry/ (from https://www.vectorstyler.com/documentation/repeater/) => correct link is/repeater/geometries/
        VectorStyler @freggern
        @freggern Should be fixed now!
          freggern
          New update of the manual (https://k00.fr/xucgr0j9)
          • Support for internal links (When you click on a link to another chapter, it jumps to the correct chapter of the PDF)
          • & display now correct as &
          • Fix rendering of images as part of an HTML p element
          Included changes of the HTML pages (thx @vectoradmin)
          • Added! What is new in VectorStyler 1.1
          • Correct an internal link
          BoldlineB S 3 Replies Last reply Reply Quote 6
            Boldline @freggern
            @freggern Love that you've taken on the task to do this - thanks! It keeps getting better all the time
              Subpath @freggern
              @freggern
              i am also really gratefully for your work 👍 👍 👍
                Boldline @freggern
                @vectorstyler @freggern should we move the PDF file of the documentation over to a pinned thread in the general discussion? This way it's easy to find each time @freggern updates it? Right now it's within an random question and would be harder to go back and find later on.
                  @Boldline A pinned thread in "Tutorials" or "General Discussion" will do.
                    freggern
                    @Boldline @vectoradmin I change the first post and rename the thread title. @vectoradmin Feel free to pin the thread.
                      freggern
                      Is it intentional that the category tutorial is private. So only logined user can see the category or access threads in it?
                        @freggern Should be fixed now.
                          👍 to both Ideas.
                          I was also not so happy that the Tutorials could
                          only be read by registered forum users.
                          Found interested People unnecessarily excluded.
                            freggern
                            • tables now support to hide the first column of the modifier-tables (is hidden on the website per CSS-rule)
                            • column and row now separated by lines
                            • there was a bug where it was possible that fields get combined.
                            • redesign the info box
                            • disable all separator lines
                            • fix a bug where \ in the text doesn't display correct
                            • add 1 cm to the textlinewidth
                            • Updated some images like color palette and layer panel
                            • Add shortcuts
                            1 Reply Last reply Reply Quote 7
                              freggern
                              New update, only include changes of the HTML pages (thx @vectoradmin) - (https://k00.fr/xucgr0j9).
                              • Add shortcuts
                                freggern
                                New update with all the changes @vectoradmin did to the documentation.
                                • Added: Shape Effects -> Outline -> Node Bump
                                • Added: Path Panal -> Describe fourth row
                                • Updated: Images for like Preferences
                                • Update Shortcuts (was already in an unannounced release of the PDF manual)
                                • Typos
                                  @freggern You're doing an awesome job keeping the pdf manual updated and available. thank you for all your hard work.
                                  A spacing issue I wanted to bring to your attention - not sure if there's an easy fix.
                                  i noticed a few cases in the table of contents, especially as the number switch from two digits to three -the space gets tight and the letters join together.
                                  further down there's some similar spacing issues as the secondary numbers hit three digits
                                  0_1647966738302_ba205407-dc4e-47ed-a502-95e712e6d0b5-BLD 2022-03-22 at 12.30.05.png
                                    freggern
                                    @Boldline I updated the PDF with a different spacing configuration for the TOC, so the overlap should not happen anymore.
                                      Boldline @freggern
                                      @freggern That looks so much better - thanks for getting that fixed up.
                                        freggern @Boldline
                                        @Boldline 👍 If you notice something else or have another idear to improve, let me know.
                                          freggern
                                          New bigger Update:
                                          Content
                                          • Thanks to @Victor-Vector I added the Boolean Operations Reference Guide Images to the PDF-Manual. More information here: https://www.vectorstyler.com/forum/topic/1758/boolean-operations-reference-guide
                                          A lot of redesigns
                                          In this update, I focus on the design that I duck out because of needed code changes of the import script.
                                          • Redesign the chapter title at the beginning of a chapter
                                          • Redesign completely the tables to a modern design and support for table headers (when exists)
                                          • Redesign the information boxes that it match to the table and chapter design
                                          • Update the title page with a date and sources, and adjust the size of the title.
                                          • Update the page header
                                          Bugs
                                          • Fix a bug in the table
                                          Victor VectorV 1 Reply Last reply Reply Quote 3
                                          • Victor VectorV Offline
                                            Victor Vector @freggern
                                            @freggern I like the redesign changes you made. Thanks for the new version!
