    VectorStyler Manual | PDF
    70 Posts 10 Posters 240.8k Views 9 Watching
      freggern
      I try to write a python script convert the local html files to a single pdf. Here is the result
      https://k00.fr/xucgr0j9
      It's a start, but there a a lot of things to optimize, before it's usable:
      • Support for nested lists
      • Support for italic font
      • Scaling of Images and Position in the pdf (detect css class names of figures for position)
      • Table overflow from pages and design
      • Better design of all elements
      • Ignore pages like "License term"
        VectorStyler @freggern
        @freggern The PDF export looks good. I wonder if there is a PDF generator tool from markdown / css / html template
        The documentation pages are generated with hugo.
          Subpath @freggern
          @freggern
          If i could i would give a +110 for that Idea.
          That the VectorStyler documentation
          may also be available as a PDF file for offline reading.
          This has been a big wish of mine for a while.
            freggern
            I updated the manual pdf (see link above).
            • Design optimization: titlepage, font, quote-element...
            • Support for nested elements, like lists, figures
            • Support for numeric list / italic font
            • Images scaling optimization
            • Table overflow optimization
            • Smaller bugs
            @vectoradmin There are some tools out there. But I only found tools for single page files.
            S R 2 Replies Last reply Reply Quote 2
              Subpath @freggern
              @freggern
              Super !!! Big Thanks.
              I really appreciate it.
                Took a look at the updated PDF manual.
                I am very impressed. Very well done!
                • J Offline
                  Jono
                  Thanks, will have a good read. 👍 ☺
                  • R Offline
                    richbyte @freggern
                    @freggern Thank You for making this! 👋
                      freggern
                      Small update of the manual (https://k00.fr/xucgr0j9)
                      • Alternative rendering for EULA pages to reduce space (page 50)
                      Included changes of the html pages (thx @vectoradmin)
                      • New chapters for Repeater (page 1305)
                      • Additions! Shortcuts (Win, Mac), Change Colors -> Intensity, Preferences -> Document Editor settings, Layer -> Layer Panel Options, Toolbox -> Symbol Tools, Editpath -> The Trim and Join Tool
                      • profileicon.png fixed
                        Boldline @freggern
                        @freggern Thanks for doing this and for keeping it updated as we go along.
                        If I see an error or misspelling in the documentation, should I be alerting both you and @vectoradmin ?
                          freggern
                          It depends on where the error or misspelling can be found. I only need to know when it happens only in the pdf file. I can do nothing when the misspelling is on the documentation website. I generate the pdf file in 3 steps that I trigger: Crawl the website, generate a latex file with python out of the website files and then generate the pdf file from the latex file. I don't plan to manually fix misspelling or errors that can be found in the website files. I can only fix "errors" that happend in the process of generating the pdf file.
                          Like for example on my todo list:
                          • & like Canvas & Artboard doesn't show as Canvas & Artboard
                          • Color Palette Bar has some not correct rendered images
                          • SVG EFFECTS - Diffuse Light has some not correct rendered images
                          • Better floating positioning for images
                          • Support for intern links in the pdf
                            @Boldline Let me know if there are spelling errors in the documentation.
                            You can also post it here.
                              @vectoradmin no problem - minor one in the "shape paint" section.
                              "Original"
                              0_1641278430754_868c69bd-94be-4453-a707-09ce9fcad8ea-BLD 2022-01-04 at 01.38.20.png
                                freggern
                                @vectoradmin There is a wrong link on the page https://www.vectorstyler.com/documentation/repeater/ unter the overview headline
                                • "Not Found" (404) at link https://www.vectorstyler.com/documentation/repeater/geometry/ (from https://www.vectorstyler.com/documentation/repeater/) => correct link is/repeater/geometries/
                                  @freggern Should be fixed now!
                                    freggern
                                    New update of the manual (https://k00.fr/xucgr0j9)
                                    • Support for internal links (When you click on a link to another chapter, it jumps to the correct chapter of the PDF)
                                    • & display now correct as &
                                    • Fix rendering of images as part of an HTML p element
                                    Included changes of the HTML pages (thx @vectoradmin)
                                    • Added! What is new in VectorStyler 1.1
                                    • Correct an internal link
                                    BoldlineB S 3 Replies Last reply Reply Quote 6
                                      Boldline @freggern
                                      @freggern Love that you've taken on the task to do this - thanks! It keeps getting better all the time
                                        Subpath @freggern
                                        @freggern
                                        i am also really gratefully for your work 👍 👍 👍
                                          Boldline @freggern
                                          @vectorstyler @freggern should we move the PDF file of the documentation over to a pinned thread in the general discussion? This way it's easy to find each time @freggern updates it? Right now it's within an random question and would be harder to go back and find later on.
                                            @Boldline A pinned thread in "Tutorials" or "General Discussion" will do.
