    Bug List for Version 1.3
    124 Posts 4 Posters 18.6k Views 4 Watching
      VectorStyler @monsterfox
      @monsterfox Is this something that occurs with the repeater?
      Send me the file that contains these shapes.
        monsterfox @VectorStyler
        @VectorStyler Sent to your email, please check
          @monsterfox Got it, I will try to figure this out
            @VectorStyler https://youtu.be/S6-ixH8OxG4 When editing a shape name, deleting one "2" causes endless garbled characters that cannot be removed.
              @monsterfox I will try to replicate this.
              What is the input method selected in Windows?
                @VectorStyler This has nothing to do with the input method. I was deleting characters without typing any input.
                  @VectorStyler https://youtu.be/MQVmn_gYtuA
                  1.vstyler
                    @VectorStyler https://youtu.be/ZGJxd6ebgus
                    1.vstyler
                      @monsterfox Regression, fix will be uploaded soon
                        @VectorStyler https://youtu.be/MrcnUe28vZI
                        2.vstyler
                        When adding a second graphic symbol in VectorStyler for use in the repeater, it becomes distorted.
                          @monsterfox In the grid repeater options set the Adjust field to 0
                            @VectorStyler https://youtu.be/SLNsOzXtN9w
                            When switching the layout of the selection toolbox, some tools go missing and the full set of tools cannot be displayed properly.
                              @monsterfox If you change the window size, will it reset the layout?
                                @VectorStyler No. Sometimes even restarting the program has no effect.
                                  @monsterfox I will try to fix this.
                                    @VectorStyler https://youtu.be/TWGHJhvrEtw
                                    23.vstyler
                                    I’m not sure if it’s a file issue. I’ve tried other new files, and this tool and panel still don’t work.
                                      @VectorStyler https://youtu.be/wDyIBAdpCI8
                                      3.vstyler
                                      The dimensions obtained by clicking to select the shape are different from those by marquee‑selecting the entire graphic.
                                        I opened a bug on this.
                                          23.vstyler
                                          What tool is used in this case? I cannot see this from the video.
                                            3.vstyler
                                            I cannot replicate this.
                                            What is shown in the transform panel if selecting all with Control+A ?
