    Bug List for Version 1.3
    122 Posts 4 Posters 18.5k Views 4 Watching
      monsterfox @VectorStyler
      @VectorStyler https://youtu.be/fYY9CcHI3SY
      After mirroring a rotated rectangle, the resulting selection does not follow the rectangle shape. Hope this issue can be fixed.
        VectorStyler @monsterfox
        I will try to find a solution for this, but currently the reflect tool "flattens" existing transforms.
        The problem here is that the order of non-flattened transformations is scale + rotate, if a new scaling (mirroring is one) comes, then the previous scale+rotate must be flattened
          The gray one is the original custom shape, and the red one is the custom shape rotated by 90 degrees. If the red one is not converted to curves, both custom shapes will have identical forms.
            @monsterfox Is this something that occurs with the repeater?
            Send me the file that contains these shapes.
              @VectorStyler Sent to your email, please check
                @monsterfox Got it, I will try to figure this out
                  @VectorStyler https://youtu.be/S6-ixH8OxG4 When editing a shape name, deleting one "2" causes endless garbled characters that cannot be removed.
                    @monsterfox I will try to replicate this.
                    What is the input method selected in Windows?
                      @VectorStyler This has nothing to do with the input method. I was deleting characters without typing any input.
                        @VectorStyler https://youtu.be/MQVmn_gYtuA
                        1.vstyler
                          @VectorStyler https://youtu.be/ZGJxd6ebgus
                          1.vstyler
                            @monsterfox Regression, fix will be uploaded soon
                              @VectorStyler https://youtu.be/MrcnUe28vZI
                              2.vstyler
                              When adding a second graphic symbol in VectorStyler for use in the repeater, it becomes distorted.
                                @monsterfox In the grid repeater options set the Adjust field to 0
                                  @VectorStyler https://youtu.be/SLNsOzXtN9w
                                  When switching the layout of the selection toolbox, some tools go missing and the full set of tools cannot be displayed properly.
                                    @monsterfox If you change the window size, will it reset the layout?
                                      @VectorStyler No. Sometimes even restarting the program has no effect.
                                        @monsterfox I will try to fix this.
                                          @VectorStyler https://youtu.be/TWGHJhvrEtw
                                          23.vstyler
                                          I’m not sure if it’s a file issue. I’ve tried other new files, and this tool and panel still don’t work.
                                            @VectorStyler https://youtu.be/wDyIBAdpCI8
                                            3.vstyler
                                            The dimensions obtained by clicking to select the shape are different from those by marquee‑selecting the entire graphic.
