Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?
@Boldline One thing: if you enable "Transformed Stroke" in the options of the top layer, then all objects inside will have transformed stroke.
Magix Graphics Designer have a Toogle in the Context Bar
once set Strokes will be scaled even if you close and restart
the Programi had also a quick look in CorelDraw and Affinity Designer
in CorelDraw I found a toggle in the object properties panel
where you can set this per object (of course also per group)
-- but I guess there is also a general toggleIn Affinity Designer there is a toggle in the Stroke panel
Once set, it will scale the stroke of all newly created objects/shapes
@Subpath I'm all for an easily accessible toggle for this, but not for being the default mode of operation.
Is AI, CDR, AD and Magix Xara like this by default?
(Rhetorical question, btw).
@b77 Perhaps Illustrator had things set to the novice user by default? I never had to worry about switching the strokes to scale with the object in the years I used Illustrator - but then again other things like winding path were not something that needed adjusting either
@Boldline I have no idea if it was the novices or avoiding unwanted stroke differences you need to fix afterwards, or both, but I guess you enabled the 'Scale Strokes & Effects' option in AI's Preferences > General and forgot about it. That's why you didn't have to worry about if afterwards.
IMO it's best to have a setting for this in Preferences AND an easily accessible toggle in the Transform or Stroke panel.
@b77 said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
It's very possible
Do not know it for AI because I do not use Illustrator
(You may remember, I don't like the user interface and the handling
To answer your question:
I would say CDR and AD definitely not.
.Magix Xara also not, in a new installation.
But as I wrote, once set it stays active even if you restart the program, until you turn it off again.
The Toogle is as I wrote in the Contex Bar and very easy to reach.
Here a Pic:
.I have no particular need for it, so I can live with a toggle
But unfortunately I have to honestly say that the VectorStyler method of scaling strokes is,
in my eyes, the most unsual I came across
( maybe because of the roles and styles ? )
( I dont like it and haven't found, until this time, any beauty in it yet, that's why I don't use it )in every other vector graphics program that i know, it is so much more seamless and easier.
@Subpath said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
I'd be interested to hear what you feel would improve it and make it more of a seamless process - also what do you do instead of scaling in VS?
@Boldline There is also a "Transformed Stroke" option in Document Setup. This will affect newly created objects.
As i only play with graphics and try out the ideas that go around in my head.
( Dont work no longer as a professional )
For this i use the programs that have the tools that can help me with the realization.
.Short note and praise for VS:
Since VS has so many useful and interesting tools by the way, I try most ideas in VS
since I bought a copy. (I think that says a lot)
.I don't really have a need for scaled strokes if I need it,
I just set a different stroke widthIf I really need it I would try to copy my design into AD, CDR or Magic Graphics Designer
and get it done there. (or maybe solve it via the outline effects ?).@Boldline
...I'd be interested to hear what you feel would improve it and make it more of a seamless process...As i dont really know the Concept behind it, why it should or must work this way
(never saw something like this before)
i can not say how to streamline it
( toggle could be a first start ? )
I just set a different stroke widthMaybe we are thinking of two different things? I'm talking about designing something at one size and then needing to group it and scale it up - the entire design element with fills and strokes included and wanting them to all stay relative in size to one another in the process.
@Boldline said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
well, dont think that we talk about different things. That you like to scale your entire design elements
in relative in size to one another, is very clear to me.
But i cant help you out in this case.
Edited:
(well you mentioned yet effect scaling and i wrote only about stroke scaling )i just wrote that i am not in need of this kind of scaling in VS and i dont like
to used it in VS. So if i need some different stroke width
i just set it.
A sticky button would be really handy for this as 90% of the time I need strokes to scale
@Dazmondo When creating new documents, enable the "Transformed Stroke" option in the Document Setup -> General view.
Doesn't work for me - the strokes only scale when grouped ????? or if scale image filters is ticked
@VectorStyler It looks like it doesn't work for parametric shapes (smart shapes). Easily fixable, I guess.
@Dazmondo Convert them to curves and this works as expected.
@Dazmondo Yes, a few parametric shapes are not "scaled" (rectangle, ellipse).
An other way to go around this is to disable the Direct Shape Transformation option in Preferences -> Editing Options 2 (bottom-right corner).
An other way to go around this is to disable the Direct Shape Transformation option in Preferences -> Editing Options 2 (bottom-right corner).Done and working ----
